Any successful radiator in engine compartment conversions?, Or other than front trunk installs? |
Mueller |
Dec 5 2014, 01:05 PM
I know this had been tried 7+ years ago, I was wondering if since then has anyone done a watercooled conversion and not put the radiator in the front trunk?
effutuo101 |
Dec 5 2014, 09:34 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans?
Inquiring minds want to know. |
Mueller |
Dec 5 2014, 09:49 PM
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans? Inquiring minds want to know. Exactly, water is a more efficient medium than air so if that compartment can shed 300hp worth of an air cooled* 3.6 it seems that same space can shed the heat from a 300hp 4 or 6 water cooled motor *anyone have the numbers how much cooling is really done by the oil? |
SirAndy |
Dec 6 2014, 11:36 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans? Inquiring minds want to know. Exactly ... No, not exactly ... On the air cooled engines, there is a clear separation between the intake side of the engine and the underside where the hot air is expelled. Without that separation, our aircooled engines would be very short-lived. I have yet to see any watercooled solution that followed the same principal. (IMG:style_emoticons/default/shades.gif) |
Brian Mifsud |
Jun 26 2015, 12:23 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans? Inquiring minds want to know. Exactly ... No, not exactly ... On the air cooled engines, there is a clear separation between the intake side of the engine and the underside where the hot air is expelled. Without that separation, our aircooled engines would be very short-lived. I have yet to see any watercooled solution that followed the same principal. (IMG:style_emoticons/default/shades.gif) Adding to this.. the 911 engine uses Mechanical Energy to run a Centrifugal Blower. It moves MEGA cubic feet per minute by sacrificing many horsepower. Estimates are up to 16HP: http://forums.pelicanparts.com/porsche-911...g-fan-cost.html Think about how big a 16HP electric motor is... In a 914, you need brute force to pull the air down and through the engine bay. I think this is the fundamental reason why a front mounted radiator is far more efficient. |
Mueller |
Jun 26 2015, 04:37 PM
Adding to this.. the 911 engine uses Mechanical Energy to run a Centrifugal Blower. It moves MEGA cubic feet per minute by sacrificing many horsepower. Estimates are up to 16HP: http://forums.pelicanparts.com/porsche-911...g-fan-cost.html Think about how big a 16HP electric motor is... In a 914, you need brute force to pull the air down and through the engine bay. I think this is the fundamental reason why a front mounted radiator is far more efficient. hmmm, maybe we are looking at this the wrong way....perhaps it should be suck and not blow? (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/av-943.gif) Radiator setups with pull type fans are more efficient than those with pusher fans... |
Lo-Fi Version | Time is now: 21st May 2024 - 11:04 PM |
