Any successful radiator in engine compartment conversions?, Or other than front trunk installs? |
Mueller |
Dec 5 2014, 01:05 PM
I know this had been tried 7+ years ago, I was wondering if since then has anyone done a watercooled conversion and not put the radiator in the front trunk?
effutuo101 |
Dec 5 2014, 09:34 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans?
Inquiring minds want to know. |
Mueller |
Dec 5 2014, 09:49 PM
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans? Inquiring minds want to know. Exactly, water is a more efficient medium than air so if that compartment can shed 300hp worth of an air cooled* 3.6 it seems that same space can shed the heat from a 300hp 4 or 6 water cooled motor *anyone have the numbers how much cooling is really done by the oil? |
SirAndy |
Dec 6 2014, 11:41 PM
Resident German Group: Admin Posts: 41,636 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
water is a more efficient medium than air so And the (armchair?) engineer in me cringes at that statement. Because last time i checked each and every "water-cooled" car i know of uses air to expel the heat from the system. (IMG:style_emoticons/default/rolleyes.gif) |
worn |
Jun 26 2015, 07:11 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
water is a more efficient medium than air so And the (armchair?) engineer in me cringes at that statement. Because last time i checked each and every "water-cooled" car i know of uses air to expel the heat from the system. (IMG:style_emoticons/default/rolleyes.gif) You have to admit that the phase change provides a cushion: if all else fails it ca boil over. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:37 PM |
