Subaru conversion help needed |
mepstein |
Dec 11 2014, 07:13 AM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm bringing home a subaru svx in the next week or 2. Dropping it off at my mechanic to pull the engine. Besides the entire wire harness and ecu, what else should I pull from the car? Thanks, mark
mgp4591 |
Dec 11 2014, 01:36 PM
914 Guru Group: Members Posts: 5,372 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I'm using the radiator out of my SVX in a lay-down slight angle configuration and it works. Fans and all fit, then run the hoses out the bottom plus saves me the trouble of getting new sheetmetal for my front trunk bottom- mines all bent up but solid. Does the fuel pump have to have the tank removed to get it or does it pull out from the floor like lots of other cars? My SVX runs strong, almost hard to part it out for donation but that's what I bought it for so my pump and running gear is good... it'll be good to share notes with someone else doing this at the same time!
904svo |
Dec 11 2014, 03:34 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I'm using the radiator out of my SVX in a lay-down slight angle configuration and it works. Fans and all fit, then run the hoses out the bottom plus saves me the trouble of getting new sheetmetal for my front trunk bottom- mines all bent up but solid. Does the fuel pump have to have the tank removed to get it or does it pull out from the floor like lots of other cars? My SVX runs strong, almost hard to part it out for donation but that's what I bought it for so my pump and running gear is good... it'll be good to share notes with someone else doing this at the same time! The fuel pump and gas gauge sender can be removed thru the access panels in the trunk. Don't forget the fuel pump controller mounted in the rear fender well in the trunk. |
Lo-Fi Version | Time is now: 15th May 2024 - 09:38 AM |
