Subaru conversion help needed |
mepstein |
Dec 11 2014, 07:13 AM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm bringing home a subaru svx in the next week or 2. Dropping it off at my mechanic to pull the engine. Besides the entire wire harness and ecu, what else should I pull from the car? Thanks, mark
a914622 |
Dec 16 2014, 10:26 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Wait wait wait? A 4.44 trany? Did someone do a tranny swap? They must have! The bigger problem with the svx autos was the final gear ratio was to low and the fluid did flow at a high enough rate to cool properly. Final ratio was like 3.90.
The 4.44 trany would be preferable. Is the tranny in you svx a manual? It to bad you live on the other coast, I have a 2000 5speed I got just to measure the insides. I would almost give it to you. |
mepstein |
Dec 17 2014, 07:11 AM
Wait wait wait? A 4.44 trany? Did someone do a tranny swap? They must have! The bigger problem with the svx autos was the final gear ratio was to low and the fluid did flow at a high enough rate to cool properly. Final ratio was like 3.90. The 4.44 trany would be preferable. Is the tranny in you svx a manual? It to bad you live on the other coast, I have a 2000 5speed I got just to measure the insides. I would almost give it to you. It had a trany swap but it's an auto |
DBCooper |
Dec 17 2014, 08:14 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Do you intend to use an automatic? When I was trying to find just Subaru inner CV joints (part number 28392FE020) that same inner CV was used in both manual and automatic transmissions. I was interested in applications, what cars would have the CV's (DOJ's) I needed, so I didn't look further, but that should mean that an automatic transmission's axles would be adaptable, interchangeable with manual transmissions. You'll need to check to confirm all that, but if you can use manual transmission inner CV's that should make fitting an automatic a bit easier. Check that CV number at some place like parts.com to see all the applications.
Lo-Fi Version | Time is now: 15th May 2024 - 09:43 AM |
