Experience with the HF Scissor Lift, (merged) |
DMCF1Fast |
Dec 13 2014, 08:31 AM
Member Group: Members Posts: 51 Joined: 14-August 11 From: Allen, TX Member No.: 13,438 Region Association: Southwest Region |
I'm thinking about getting this lift from Harbor Freight and wanted to know if the adjustments for the jacking pads fit 914s and 911s well? I think I saw some people had this lift on here a while back but can't find the posts when I search. Also if you have experience with this lift did you like it?
http://t.harborfreight.com/6000-lb-capacit...lift-91315.html |
Elliot Cannon |
Dec 13 2014, 11:37 AM
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible.
Attached image(s) |
Tom_T |
Dec 13 2014, 12:41 PM
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible. (IMG:http://www.914world.com/bbs2/uploads/post-7407-1418492211.jpg) Hmmmm .... (IMG:style_emoticons/default/idea.gif) .... That may be a solution for our tiny 17'-6" w x 18'-0" L (outside) x 7'-6" ceiling ht. 1921 "Model T" garage. However, doesn't the idea of using jack stands + a scissors lift defeat the purpose of using a lift vs. good floor jack & jack stands?? (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Dec 13 2014, 06:33 PM
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible. (IMG:http://www.914world.com/bbs2/uploads/post-7407-1418492211.jpg) Hmmmm .... (IMG:style_emoticons/default/idea.gif) .... That may be a solution for our tiny 17'-6" w x 18'-0" L (outside) x 7'-6" ceiling ht. 1921 "Model T" garage. However, doesn't the idea of using jack stands + a scissors lift defeat the purpose of using a lift vs. good floor jack & jack stands?? (IMG:style_emoticons/default/confused24.gif) The scissor lift will hold the car up higher than floor jacks and jack stands. I put two jack stands under the lift in case the hydraulic pressure fails then the mechanical lock fails. If both those things happen (not likely) the lift will stop at the jack stands and save my old ass from being crushed. It's a belt and suspenders kinda thing. By the way, my "garage" is an enclosed car-port. The floor is 17X17.5 with a seven foot ceiling. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 11:27 PM |
