Experience with the HF Scissor Lift, (merged) |
DMCF1Fast |
Dec 13 2014, 08:31 AM
Member Group: Members Posts: 51 Joined: 14-August 11 From: Allen, TX Member No.: 13,438 Region Association: Southwest Region |
I'm thinking about getting this lift from Harbor Freight and wanted to know if the adjustments for the jacking pads fit 914s and 911s well? I think I saw some people had this lift on here a while back but can't find the posts when I search. Also if you have experience with this lift did you like it?
http://t.harborfreight.com/6000-lb-capacit...lift-91315.html |
Elliot Cannon |
Dec 13 2014, 11:37 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible.
Attached image(s) |
Tom_T |
Dec 13 2014, 12:41 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible. (IMG:http://www.914world.com/bbs2/uploads/post-7407-1418492211.jpg) Hmmmm .... (IMG:style_emoticons/default/idea.gif) .... That may be a solution for our tiny 17'-6" w x 18'-0" L (outside) x 7'-6" ceiling ht. 1921 "Model T" garage. However, doesn't the idea of using jack stands + a scissors lift defeat the purpose of using a lift vs. good floor jack & jack stands?? (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Dec 13 2014, 06:33 PM
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible. (IMG:http://www.914world.com/bbs2/uploads/post-7407-1418492211.jpg) Hmmmm .... (IMG:style_emoticons/default/idea.gif) .... That may be a solution for our tiny 17'-6" w x 18'-0" L (outside) x 7'-6" ceiling ht. 1921 "Model T" garage. However, doesn't the idea of using jack stands + a scissors lift defeat the purpose of using a lift vs. good floor jack & jack stands?? (IMG:style_emoticons/default/confused24.gif) The scissor lift will hold the car up higher than floor jacks and jack stands. I put two jack stands under the lift in case the hydraulic pressure fails then the mechanical lock fails. If both those things happen (not likely) the lift will stop at the jack stands and save my old ass from being crushed. It's a belt and suspenders kinda thing. By the way, my "garage" is an enclosed car-port. The floor is 17X17.5 with a seven foot ceiling. (IMG:style_emoticons/default/biggrin.gif) |
Tom_T |
Dec 14 2014, 07:08 PM
Hmmmm .... (IMG:style_emoticons/default/idea.gif) .... That may be a solution for our tiny 17'-6" w x 18'-0" L (outside) x 7'-6" ceiling ht. 1921 "Model T" garage. However, doesn't the idea of using jack stands + a scissors lift defeat the purpose of using a lift vs. good floor jack & jack stands?? (IMG:style_emoticons/default/confused24.gif) The scissor lift will hold the car up higher than floor jacks and jack stands. I put two jack stands under the lift in case the hydraulic pressure fails then the mechanical lock fails. If both those things happen (not likely) the lift will stop at the jack stands and save my old ass from being crushed. It's a belt and suspenders kinda thing. By the way, my "garage" is an enclosed car-port. The floor is 17X17.5 with a seven foot ceiling. (IMG:style_emoticons/default/biggrin.gif) Would that be a Red-Green Show sort of belt & suspenders Elliot? (IMG:style_emoticons/default/laugh.gif) I get what you mean though, but I thought you meant a set of those +/- 48-60" tall jack stands. Otherwise, I'd think that the extra force from the drop if the scissors jack failed, might either kick out the short jack stands or crush then from the momentum of the drop down. Your carport/garage is about the same size as mine, so I think it will work without my having to "raise the roof". Thanx! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 9th May 2024 - 06:09 PM |
