Experience with the HF Scissor Lift, (merged) |
DMCF1Fast |
Dec 13 2014, 08:31 AM
Member Group: Members Posts: 51 Joined: 14-August 11 From: Allen, TX Member No.: 13,438 Region Association: Southwest Region |
I'm thinking about getting this lift from Harbor Freight and wanted to know if the adjustments for the jacking pads fit 914s and 911s well? I think I saw some people had this lift on here a while back but can't find the posts when I search. Also if you have experience with this lift did you like it?
http://t.harborfreight.com/6000-lb-capacit...lift-91315.html |
PancakePorsche |
Dec 27 2014, 11:43 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
The HF lift you refer to is a exact copy of my Bendpak lift. I love it and it works well with 911-914 cars. It does block center of car and not good for transmission work on front engined, rear drive.
It folds up so flat I park my car trailer over it. It also does not go high enough to over lift a car in a regular garage. I can drop engine in my 914's easily in less than half hour. I installed a hydraulic quick disconnect so I can store power unit in my shed. quote name='DMCF1Fast' date='Dec 13 2014, 06:31 AM' post='2121916'] I'm thinking about getting this lift from Harbor Freight and wanted to know if the adjustments for the jacking pads fit 914s and 911s well? I think I saw some people had this lift on here a while back but can't find the posts when I search. Also if you have experience with this lift did you like it? http://t.harborfreight.com/6000-lb-capacit...lift-91315.html [/quote] |
Lo-Fi Version | Time is now: 10th May 2024 - 06:50 AM |
