Eliminating the Electrical Box and Wiring, under the passenger seat in a '75 |
euro911 |
Dec 15 2014, 01:24 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'd like to eliminate the electrical relay box and associated wiring that's under the passenger seat. Most of the connections look pretty bad and a PO did bypass some of the connections.
I'm never going to restore this car back to stock '75 specs. I think this it's just something that's eventually going to go wrong. Has anyone else eliminated this stuff? ... and how did you do it? |
SLITS |
Dec 15 2014, 07:33 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I think that box is the seat belt relay system. Join the two big yellow (w/ red trace?) wires together and toss the rest. Seat belt buzzer and dash light won't work after removal, but starter will.
JeffBowlsby |
Dec 15 2014, 07:35 AM
914 Wiring Harnesses Group: Members Posts: 8,482 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Bypass the two large yellow wires, other than that the other wires can just be abandoned. Leave them in the relay base or wrap them to assure they do not short to ground if you don't have the relay base any longer.
Attached image(s) |
NS914 |
Dec 15 2014, 12:21 PM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Thanks for this picture Jeff (and Euro11 for posting) ...I have joined the two wires together already but had that mess as well....will be cleaning that and many other items up this winter.
Grant |
ndfrigi |
Dec 15 2014, 01:01 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Thanks Mark for starting the thread! So all the wiring connections below the passenger seat are only for door buzzer and seat belt warning? If yes, can we just cut all the wires and make the lower floor clean under passenger seat?
Thanks! |
JeffBowlsby |
Dec 15 2014, 01:12 PM
Thanks Mark for starting the thread! So all the wiring connections below the passenger seat are only for door buzzer and seat belt warning? If yes, can we just cut all the wires and make the lower floor clean under passenger seat? Thanks! NNNNOOOOOooooooooOOOooooooOOOOoooO!!!!!!!! Don't cut any wires ever, for any reason, there is never a need, it can cause more problems than it solves and is difficult to repair correctly. Wires under the passenger seat of 1974-76 cars are more than just the door buzzer and seatbelt interlock. The two big yellow wires are the main ignition circuit. Study the schematics to understand the others. |
ndfrigi |
Dec 15 2014, 01:15 PM
ok thanks! my 75 1.8 FI has the thick yellow wire already by pass. I was just thinking if we can totally eliminate everything. Well you said the big NO already. thanks again!
GregAmy |
Dec 15 2014, 02:13 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
My 1974 2L has absolutely zero wires under the passenger seat...
JeffBowlsby |
Dec 15 2014, 02:39 PM
euro911 |
Dec 16 2014, 12:14 AM
Bypass the two large yellow wires, other than that the other wires can just be abandoned. Leave them in the relay base or wrap them to assure they do not short to ground if you don't have the relay base any longer. Thanks Ron & Jeff. The large yellow wire is already spliced together. The problem I have, is that the plastic terminal block next to the relay is pretty deteriorated and some of the connection tabs are gone. Also, some of the slide on lugs on the wiring ends have corroded away and are already taped up. I was hoping I could just remove the whole mess if possible, but I've never been able to decipher Porsche's electrical diagrams (IMG:style_emoticons/default/headbang.gif) |
Dave_Darling |
Dec 16 2014, 10:54 AM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There are two things under the seat. The Dreaded Seatbelt Interlock Relay, and the door buzzer. The only wires going to either that affect anything else are the big fat yellow or yellow/red wires that go to the starter. Splice those together, and unplug the relay and buzzer, and the whole little panel is a nothing.
If you want, you can cut all of those wires. Make sure to connect together all of the ones that were crimped into a single connector, though. That is, if two wires were crimped into a single metal connector, connect them together. There should be a few of those. I do not recommend cutting anything--I'm in Jeff's camp on this one. Cutting is a very difficult operation to reverse.... But it is your car in the end. --DD |
Cap'n Krusty |
Dec 16 2014, 11:54 AM
Remove the connectors from the box and shrink tube each connector.
The Cap'n |
euro911 |
Dec 16 2014, 03:33 PM
I can do that. Then I can remove the defunct relay/terminal block completely, right?
Cap'n Krusty |
Dec 16 2014, 04:24 PM
Yup. If possible, I'd move the resulting collection of wires up behind the backpad. Get 'em off the floor and out of the way.
The Cap'n |
ndfrigi |
Dec 16 2014, 06:09 PM
Thanks Mark for starting this thread! And thanks to all again for sharing your knowledge and experienced!
ThunderbirdDrive |
Jun 3 2016, 11:40 AM
Newbie Group: Members Posts: 31 Joined: 3-March 16 From: Toronto Canada Member No.: 19,724 Region Association: Canada |
I know I'm digging up an old post, but this has been most helpful.
I just picked up a '76 (my first time in a 914) and while going through all the various wiring runs, I came across a large bundle of wires with nothing attached under the passenger seat. Thanks to this post I now know what these are. Will look to pull them up behind the backpad if I can. Right now they are bundled in a ball under the carpet. |
jim_hoyland |
Jun 3 2016, 08:36 PM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
One other thing: IIRC there is a grey wire that runs from the ignition switch to those relays under the seat. It's hot when the key is left in the ignition......you can verify thus with a simple circuit tester. (IMG:style_emoticons/default/smile.gif)
76-914 |
Jun 4 2016, 08:30 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,492 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Damn, I miss the Cap'n. (IMG:style_emoticons/default/sad.gif)
abes914 |
Jun 4 2016, 10:03 AM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
I was thinking the same thing. |
914werke |
Oct 21 2018, 10:44 AM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Time to reboot this topic ...again.
I think the the topic of defeating or bypassing the nanny circuit is by now well understood & documented but after a couple of searches the actual "logic" or how its supposed to work, doesnt seem to be clearly described. So here goes: IIUC (if I understand correctly) if the system is is place and working as it should, the ignition can't be triggered unless both a butt is in the seat AND the seatbelt for driver is connected. There is both a pressure sensor in the seat cushion and the seat belt receptacle with electrical contacts that close/connect the circuit. There is also a buzzer and a warning light on the dash but scouring the various manuals I haven't found a clear description of how the dash light is supposed to work. The Buzzer will sound if the key is in the Ign., not to be confused with door ajar buzzer, but if you aren't sitting in the drivers seat & reach in to key the Ignition should it start ? What happens with the warning light? Is it supposed to stay illuminated until you latch the seat belt or just flash when keying the ignition? |
Lo-Fi Version | Time is now: 27th April 2024 - 10:09 AM |
