Eliminating the Electrical Box and Wiring, under the passenger seat in a '75 |
euro911 |
Dec 15 2014, 01:24 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'd like to eliminate the electrical relay box and associated wiring that's under the passenger seat. Most of the connections look pretty bad and a PO did bypass some of the connections.
I'm never going to restore this car back to stock '75 specs. I think this it's just something that's eventually going to go wrong. Has anyone else eliminated this stuff? ... and how did you do it? |
Dave_Darling |
Dec 16 2014, 10:54 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There are two things under the seat. The Dreaded Seatbelt Interlock Relay, and the door buzzer. The only wires going to either that affect anything else are the big fat yellow or yellow/red wires that go to the starter. Splice those together, and unplug the relay and buzzer, and the whole little panel is a nothing.
If you want, you can cut all of those wires. Make sure to connect together all of the ones that were crimped into a single connector, though. That is, if two wires were crimped into a single metal connector, connect them together. There should be a few of those. I do not recommend cutting anything--I'm in Jeff's camp on this one. Cutting is a very difficult operation to reverse.... But it is your car in the end. --DD |
Lo-Fi Version | Time is now: 13th May 2024 - 07:09 PM |
