039.198.075, engine gasket set 94mm 2.0 |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
type47 |
Dec 15 2014, 09:17 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
PET 039 198 075
A Valve Cover Gasket (2) CORK B Exhaust Gasket Ring (4) COPPER C Oil Breather Gasket (1) CORK D Sump cover O-ring (1) RED RUBBER 77 X 4 mm E Muffler Flange Gasket (2) Metalic / Fiber F Flywheel O-ring (1) Graphite Impregnated G Push rod tube inner (8) Black Rubber H Push rod tube outer (8) Green Rubber I Oil Filter Mount (1) Paper J Oil Filler Tube Gasket (1) Paper K Fuel Pump Gasket (1) Paper L Fan Hub O-Ring (1) Rubber M Oil Strainer Crush Washer (2) Aluminum N Oil Plug Crush Washer (1) Copper 14 mm O Distributor O-Ring (1) Black Rubber P Oil Pickup Tube O-ring (1) Black Rubber 13.5 X 2.5 mm Q Oil Cooler Seals (2) Orange/Red Silicone R Oil Pump O-Ring (1) Black Rubber 60.8 X 2 mm S Oil Pickup Case thru Bolt Washer (1) Copper 8.2 X 16 mm T Oil Sump Crush Washer (2) Copper A6 X10 mm U Oil Pressur Control Crush Washer (1) Copper 16 mm V Oil Press Relief Valve Crush Washer (1) Aluminum 22 mm W FLYWHEEL CRUSH WASHER (1) 5 HOLE Metal X Oil Pump Gasket (1) Paper Y OIL Strainer Gaskets (2) Paper -Pair w Alum Crush Z Cylinder Base Gaskets (4) Metal 100 X 109 mm AA Cylinder Head Gaskets (4) Metal 94 X 105 X 0.7 mm 2.0 L BB Cylinder Head Gaskets(4)Metal 93 X 104 X 0.7 mm 1.7,1.8L CC, DD Not Applicable to F.I. EE INTAKE MANIFOLD GASKETS (2) BAKELITE FF CASE VIBRATION DAMPERS (6) NYLON |
Lo-Fi Version | Time is now: 19th May 2024 - 08:24 AM |
