D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
JeffBowlsby |
Dec 15 2014, 01:22 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There might be a couple things going on here. If everything is correct the engine should not operate without the MPS. Something else could be fooling it to provide fuel to make it run. MPS do fail rich. Can you pull a vacuum with a vacuum pump on the MPS or not? Sucking on it with your mouth is no where near sufficient to test its ability to maintain a vacuum.
You said its new but just to be sure check the function (continuity and resistance of the TS2, if its out of spec, it could be dumping fuel that the MPS normally provides, enough to allow it to run. Also, have you checked the injectors including the CSV? Leaking? |
DRPHIL914 |
Dec 15 2014, 03:16 PM
There might be a couple things going on here. If everything is correct the engine should not operate without the MPS. Something else could be fooling it to provide fuel to make it run. MPS do fail rich. Can you pull a vacuum with a vacuum pump on the MPS or not? Sucking on it with your mouth is no where near sufficient to test its ability to maintain a vacuum. You said its new but just to be sure check the function (continuity and resistance of the TS2, if its out of spec, it could be dumping fuel that the MPS normally provides, enough to allow it to run. Also, have you checked the injectors including the CSV? Leaking? The mps holds vac no loss or drop seen on vac pump gauge. The wires are connected to mps , it will not run when the vac is applied. . I'm going to suggest to him that he recheck the cht again and check those values on the mps that slits suggested. |
Lo-Fi Version | Time is now: 12th May 2024 - 03:53 PM |
