D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
r_towle |
Dec 15 2014, 10:55 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Get the car home.
you can do all the testing with an ohm meter, well most of it. Rich |
DRPHIL914 |
Dec 16 2014, 07:17 AM
Get the car home. you can do all the testing with an ohm meter, well most of it. Rich Rich, that is probably what i need to do. I was just at my wits end and really thought it was something non-djet related at the point where i gave up. i really did not suspect the MPS, but then i only tested the vac and that was perfect. I'd been thru everything else and was mad enough if someone had offered me $$ for what i have in it for parts(which is a lot) i would have just walked away. especially since i really needed to be driving the car this past 2 weeks. Ive been down a vehicl since i sold the boxster and regretted that, and this week an opportunity arose to get a high milage 2002 911 cabriolet for under 10K - needs a bit of work but could be a daily driver and that has taken my mind off the 914 for now- i've recommitted to getting back on the road just because im so stubburn and i cant sell it like this..... btw another member here says that (scott NH) if the vac holds the diaphragm is fine, but that its the inner electronics that have failed . if that is the case then it might fail lean when hooked up to the vac hose, and when disconnected go rich. Someone is sending me their MPS thats good to test on it. |
Lo-Fi Version | Time is now: 12th May 2024 - 11:39 AM |
