D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
r_towle |
Dec 16 2014, 11:08 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Oh, an interesting test.
Have your mechanic unplug ALL other vacuum lines and plug them at the plenum. The. Plug in the one line to the MPS, it's the only one required to run. If your DECEL valve is stuck, added vacuum may make it change the timing. If your AAR is stuck open, added vacuum may make it run lean. When I diagnose these, I do unplug all other vacuum lines from the plenum. I use rubber covers or electrical tape and close off all ports on the plenum. You can then use just the MPS to have the car run fine. If that works, you will then add ONLY one vacuum line at a time back into the system to see which one it doing it. Rich |
Bleyseng |
Dec 16 2014, 08:13 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Oh, an interesting test. Have your mechanic unplug ALL other vacuum lines and plug them at the plenum. The. Plug in the one line to the MPS, it's the only one required to run. If your DECEL valve is stuck, added vacuum may make it change the timing. If your AAR is stuck open, added vacuum may make it run lean. When I diagnose these, I do unplug all other vacuum lines from the plenum. I use rubber covers or electrical tape and close off all ports on the plenum. You can then use just the MPS to have the car run fine. If that works, you will then add ONLY one vacuum line at a time back into the system to see which one it doing it. Rich (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 01:00 PM |
