D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
brant |
Dec 19 2014, 03:51 PM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree
the factory setting are far from ideal remember how different gasoline formula's were back then! todays gas is a lot different perhaps the factory settings were better? for gasoline of the day or perhaps the factory settings were too lean even back then for fuel mileage and simplistic testing equiptment. as you rebuild one of your cores, make sure that its a 2.0 housing... the 1.7 housing have a WOT stop in the casting that you would need to grind out if you are using one of them on a bigger motor. I still can't wait to hear what happens when you plug a different, known good MPS into the car. I think that your entire problem was caused by this MPS. Hell if I know why, but i've seen it once before. you never replied.... was this MPS a NOS one? |
DRPHIL914 |
Dec 19 2014, 09:23 PM
I agree the factory setting are far from ideal remember how different gasoline formula's were back then! todays gas is a lot different perhaps the factory settings were better? for gasoline of the day or perhaps the factory settings were too lean even back then for fuel mileage and simplistic testing equiptment. as you rebuild one of your cores, make sure that its a 2.0 housing... the 1.7 housing have a WOT stop in the casting that you would need to grind out if you are using one of them on a bigger motor. I still can't wait to hear what happens when you plug a different, known good MPS into the car. I think that your entire problem was caused by this MPS. Hell if I know why, but i've seen it once before. you never replied.... was this MPS a NOS one? No, as stated in my previous post, it was rebuilt at some point but too lean. I spent a hour on it tonight adjusting slowly the mps trying to bring the mix closer to 12.7 that anders says is the target for part load mix. It's still hitting about 14 on acceleration up a slight grade. That was after adjusting the center screw about 3/4 turn. At.least it starts and runs. Tomorrow I'll work a bit more on it but will take it a quarter turn at a time , test drive, and I will keep working it down closer to the 12-13 under part to full load. I've been going back over all of anders data etc. For some.reason the idle is a bit high but that could be the lean setting as well. I have to recheck the tps setting. It seems like it is not set exactly where I set it after it was in the shop. I think there a are is fine. It was fully closed tonight after the engine warned up. |
Lo-Fi Version | Time is now: 12th May 2024 - 04:59 PM |
