D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
r_towle |
Dec 29 2014, 08:29 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
its the ambient air temp, and I have never had one fail, but this stuff is 40 years old now.
In the end, you had a bad MPS sensor. maybe with all the moving of the wiring harness you may have loosened the connection to the ambient air temp sensor, which may have done something. I cannot recall what the conditions are for that to work/not work. rich |
DRPHIL914 |
Dec 29 2014, 09:49 AM
its the ambient air temp, and I have never had one fail, but this stuff is 40 years old now. In the end, you had a bad MPS sensor. maybe with all the moving of the wiring harness you may have loosened the connection to the ambient air temp sensor, which may have done something. I cannot recall what the conditions are for that to work/not work. rich well that is certainly a possibility. we do know for sure that MPS was bad, and putting a different one, ones in made it run, but i was still having an issue. i know the harness is good but that doesnt mean there wasnt a bad connection either there or somewhere else. I thought it might even be the CHT connection. the CHT tested good but if that connection is not right that would cause issues. . it seems odd that sensor would go bad, but i do know that right now its running pretty good. I will have to wait and see if that lasts. Phil |
Lo-Fi Version | Time is now: 12th May 2024 - 11:15 PM |
