D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
Larmo63 |
Dec 29 2014, 05:37 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
After reading this thread and screwing around with my own '73 1.7 FI, I think carbs are a better solution. I know just stating this may start a whole sh*tstorm, but my new engine will have carbs.
With all these acronym parts, hoses, wires, vacuum, testing, the whole mess has me worn out. |
r_towle |
Dec 29 2014, 06:35 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
After reading this thread and screwing around with my own '73 1.7 FI, I think carbs are a better solution. I know just stating this may start a whole sh*tstorm, but my new engine will have carbs. With all these acronym parts, hoses, wires, vacuum, testing, the whole mess has me worn out. Not going to argue you out of it, but I would suggest you research what you want to do so you can achieve the goals you want. With carbs you can use a more aggressive camshaft which could deliver more power. With carbs you will have constant maintenance of the jets to keep it clean. You will need new fuel lines for today's fuel. Overall, if you approach it the right way, both carbs and FI can be fun and simple. Rich |
Lo-Fi Version | Time is now: 13th May 2024 - 08:19 AM |
