D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
rhodyguy |
Jan 4 2015, 09:27 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Remembered from long ago....I think Dave darling had a problem similar issue. Itwas traced down by brad r and the issue was the routing of the wiring for the mps. Interference from a different signal source? See if Dave remembers this. Are you currently using the mps I sent you?
DRPHIL914 |
Jan 4 2015, 05:58 PM
Remembered from long ago....I think Dave darling had a problem similar issue. Itwas traced down by brad r and the issue was the routing of the wiring for the mps. Interference from a different signal source? See if Dave remembers this. Are you currently using the mps I sent you? No . I have 2 that I wanted to test I was going to do that yesterday. But since car won't start I cant do much. Tomorrow I'm going to go back thru checking the electrical end starting with spark/coil/plug wires etc. I've already gone thru the f.i. harness. I did make sure the mps wire is not next to the spark plug wire and interfering. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:14 PM |
