D_jet trouble shooting question - car is home, journey continues, June, update- no more problem-- the fix was simple.... |
DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
DRPHIL914 |
Jun 24 2015, 01:26 PM
this goes back a few months and i never posted after resolving the issue, but after having the cold start injector disconnected, having the injectors tested, i almost gave up.
- long story short- the whole issue of sometimes starting sometimes not was caused by a bad contact in the distributor cap. - I replaced the cap and rotor and have not had an issue since!! - the center contact with a spring in it was not making solid contact all the time . so both during the cooler weather in march/april and the heat of this summer ive had not one issue with the car not starting right up. Back in december we did have the MPS die and that was replaced . just strange tha this happened so soon after that problem was diagnosed and fixed... sometimes the solution can be so simple!! |
Lo-Fi Version | Time is now: 12th May 2024 - 11:27 AM |
