Tire tuning, Not getting full tread to the ground |
Joe Ricard |
Feb 4 2005, 02:32 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Things I have learned so far about Autocrossing a 914: 1) what other people in new cars are doing Means do somethng else. 2) you may very well have the oldest car at the event 3) You started with a HP defecit Deal with and stay off the brakes and stand on the gas. 4) when you actually start getting close to the times of the New M3 Coupe everybody wants to know what you did to the motor. 5) If there is a car dripping oil on the track they stop the 914 1st for inspection. (wasn't me really)!!! I can fit everything I need in the car including tires where everyone else has cute little tire trailers. |
J P Stein |
Feb 4 2005, 02:44 PM
Here's a pic of one of my tire wheel setups at work.
The fronts are 205 X 50 V racers on 7 X 15 wheels, with -2 camber, 26 psi (cold). AIR, this was with stock T-bars & a 19mm AR bar set full soft. The rears were 225s on 7s and 140 lb springs.,-2 camber. The tire wear was quite even and the car handled very neutral. Note the outside of the tires standing very up right.....they sure as hell didn't look that way at rest! I find it difficult to believe that -2 deg is possible at the front of a 914 with the stock strut mounts in place. When I lowered mine to what I considered the max......allowing for 2 in of dampener travel, I had -1 deg. I had to go to offset strut mounts (Tarret) to get -2. BTW. I have a set of Welt offset strut mounts, one of which kinda buggered up. If anyone wants to take a chance on em' ....they're cheep (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached thumbnail(s) |
john rogers |
Feb 4 2005, 04:42 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Here's a pict of my race car at the CA Speedway rollong over a 9x23x15 Goodyear slick in the rear. Note the inside front wheel is still on the ground. I use 300# rear springs, 23mm front t-bars, stock rear sway bar and large front sway bar with a GT limited slip. The car stll sits fairly flat when cornering like this and the tire temps are within a couple of degrees across the width of the tires.
J P Stein |
Feb 4 2005, 05:43 PM
Yeah, that was a few years ago. That set-up is much closer to Joe's than my present or future one. 275 & 300 lb springs are in the budget.
Lo-Fi Version | Time is now: 15th May 2024 - 12:10 PM |
