> Where to mount the Fuel Pressure Regulator
PanelBilly
post Dec 15 2014, 11:54 PM
Post #21
Im looking for suggestions on how to plumb the fuel lines for the PMO carbs. Where should the regulator be mounted?
PanelBilly   Where to mount the Fuel Pressure Regulator   Dec 15 2014, 11:54 PM
Socalandy   I dug this picture up from when the engine was ins...   Dec 16 2014, 01:04 AM
Mark Henry   Doesn't really matter, but where ever you moun...   Dec 16 2014, 06:53 AM
stugray   In my current configuration, I have the regulator ...   Dec 16 2014, 09:21 AM
slivel   Two regulators - one in front reducing the pressur...   Dec 16 2014, 11:32 AM
SLITS   Two regulators - one in front reducing the pressu...   Dec 16 2014, 12:17 PM
Mark Henry   Wow, you used a REAL pressure regulator not the ...   Dec 16 2014, 01:16 PM
914Timo   Wow, you used a REAL pressure regulator not the B...   Dec 16 2014, 02:05 PM
Mark Henry   [quote name='SLITS' post='2123072' date='Dec 16 2...   Dec 16 2014, 02:27 PM
914Timo   The Malpassi fuel regulator I'm using is fav...   Dec 16 2014, 02:45 PM
SLITS   Wow, you used a REAL pressure regulator not the ...   Dec 16 2014, 03:14 PM
914Timo   When you use a "safety collar"** to cl...   Dec 16 2014, 03:33 PM
SLITS   When you use a "safety collar"** to c...   Dec 16 2014, 03:47 PM
Mark Henry   That must be very early, the ones I see now don...   Dec 16 2014, 04:31 PM
patssle   Or...use a fuel pump that pumps at 3-4 psi and avo...   Dec 16 2014, 04:48 PM
Mark Henry   Or...use a fuel pump that pumps at 3-4 psi and av...   Dec 16 2014, 04:53 PM
SLITS   Or...use a fuel pump that pumps at 3-4 psi and av...   Dec 16 2014, 04:54 PM
patssle   http://www.cbperformance.com/ProductDetail...roduc...   Dec 16 2014, 05:27 PM
yeahmag   I use the same one. I'd love to start data log...   Dec 16 2014, 06:53 PM
Socalandy   here's the instructions with in and out layout   Dec 17 2014, 12:29 AM
PanelBilly   That's perfect. I guessed the 2 lines in the f...   Dec 17 2014, 12:34 AM
- Lo-Fi Version Time is now: 25th May 2026 - 08:13 AM
