WTB Main Bearing .20 Case - STD Crank, Need Main Bearing Steel Back |
Ghianto66 |
Dec 17 2014, 12:37 AM
Newbie Group: Members Posts: 5 Joined: 11-November 10 From: Jakarta, Indonesia Member No.: 12,372 Region Association: Indonesia |
Hello,
Been looking for main bearing for .20 Case and STD Crank, please let me know if anyone have this bearing for spare. Cheers, Ghie |
pilothyer |
Dec 17 2014, 01:51 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Were you looking for the center main only or the full set? The center main is the only one in the set that is steel backed. Seems to be in short supply right now if steel backed is a must. If not Standard Crank, .020"/.50mm Case, Standard Thrust Is readily available.
Ghianto66 |
Dec 18 2014, 03:21 AM
twice buying from web store (i cant tell what they are) they came w/ aluminum bearing (center main). They are Mahle bearing...
i am looking for a set bearing with steel back on the center main. thank you |
pilothyer |
Dec 18 2014, 08:33 AM
Ghie............I see what you mean. You would need to look into getting Silverline or Clemax bearings made by Mahle, Here is a link to a place that may be able to get you what you need: Good luck with your search.
STEEL BACK MAIN BEARINGS or HERE |
Ghianto66 |
Dec 18 2014, 08:45 PM
thank you very much..that is much helpful
Ghie |
Lo-Fi Version | Time is now: 28th March 2024 - 04:27 PM |
