New item to work on. Guys with carbs what do you think?, phenolic spacers |
Mikey914 |
Dec 17 2014, 04:32 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at making up some of these. These are intended to help insulate the carbs from the engine further at the carb base. Who's interested?
These were available at one time for $15 each. I should be able to do a set of 4 for $24, if i can get some quantity. Figured I'd see how much interest is out there. Attached image(s) |
rhodyguy |
Dec 17 2014, 09:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if its hot outside or when the engine sits when hot you can experience heat soak to the fuel in the float chambers. can make for difficult starting until the cooler fuel is on board.
Lo-Fi Version | Time is now: 16th May 2024 - 08:57 AM |
