New item to work on. Guys with carbs what do you think?, phenolic spacers |
Mikey914 |
Dec 17 2014, 04:32 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at making up some of these. These are intended to help insulate the carbs from the engine further at the carb base. Who's interested?
These were available at one time for $15 each. I should be able to do a set of 4 for $24, if i can get some quantity. Figured I'd see how much interest is out there. Attached image(s) |
Mark Henry |
Dec 17 2014, 09:46 AM
I'm not familiar with this concept... > I've been having issues with heat transfer... I'd be in for a set! How do you know if you are having issues? -Steve They are stock on type 4 FI, a set comes in the gasket set, manifold to head. Heat soak leads to percolation, vapor lock, bad running issues. Are these for the carb to manifold? To install the phenolic spacers, one would need 8 individual gaskets for a dual carb setup. I would add the extra gaskets as well so peeps don't have to source them separately. |
Kansas 914 |
Dec 17 2014, 09:50 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I would be in for a set of 4.
Thanks Mark! |
Lo-Fi Version | Time is now: 16th May 2024 - 11:53 AM |
