New item to work on. Guys with carbs what do you think?, phenolic spacers |
Mikey914 |
Dec 17 2014, 04:32 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at making up some of these. These are intended to help insulate the carbs from the engine further at the carb base. Who's interested?
These were available at one time for $15 each. I should be able to do a set of 4 for $24, if i can get some quantity. Figured I'd see how much interest is out there. Attached image(s) |
r_towle |
Dec 17 2014, 06:44 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Just curious.
I have used just the head-->>manifold phenolic spacer and I have never had any heat issues on the manifolds or carbs. Sure, there is some heat from the studs, but never enough to make a big difference. Also, with these added gaskets, you are moving the throttle plate further away from the valve which does have a negative result. So, why add these? Rich |
bdstone914 |
Dec 19 2014, 08:24 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Just curious. I have used just the head-->>manifold phenolic spacer and I have never had any heat issues on the manifolds or carbs. Sure, there is some heat from the studs, but never enough to make a big difference. Also, with these added gaskets, you are moving the throttle plate further away from the valve which does have a negative result. So, why add these? Rich Rich What is the negative result and how is it any different than adding tall manifolds that are better for top end? Do you really think a few mm spacing will make a difference? Bruce |
lonewolfe |
Dec 19 2014, 10:47 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Just curious. I have used just the head-->>manifold phenolic spacer and I have never had any heat issues on the manifolds or carbs. Sure, there is some heat from the studs, but never enough to make a big difference. Also, with these added gaskets, you are moving the throttle plate further away from the valve which does have a negative result. So, why add these? Rich Rich What is the negative result and how is it any different than adding tall manifolds that are better for top end? Do you really think a few mm spacing will make a difference? Bruce I believe the benefit is the phenolic spacers stop the heat from traveling up the manifold. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:18 AM |
