F/S 3 Hand throttles for carbs, $99 each + shipping |
Mikey914 |
Dec 17 2014, 04:57 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have a few extra hand throttle assemblies hanging out. Let me know if you want one.
Attached image(s) |
morgan_harwell |
Jan 26 2015, 10:09 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
Thanks Mikey!
I purchased one of these hand throttles last Summer and installed it in my 914-6conversion this past weekend. Install went smoothly. My 2.4L CIS engine is an early one out of a 1973.5 911T, which was not equipped with an Auxillary Air Regulator the later CIS injected 911s got. If I remember correctly, 1973 911s also came with hand throttles. To start the cold CIS engine now: depress throttle pedal slightly, pull back new hand throttle lever, release throttle pedal, turn ignition key and neet neet VROOOM!, and now the cold engine idles by itself without stalling (IMG:style_emoticons/default/smile.gif). I have since retired the very finely crafted wood block to the wood stove. The block that I used to place between the throttle & brake pedals after start up to hold the engine at high-idle, for the past 28 years. |
eyesright |
Jan 26 2015, 11:25 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Mikey914
I bought mine last summer. I figure the installation will be an no brainer when I get to that point...but thanks for the picture and diagram. It WILL be a no brainer now. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:04 PM |
