1.7l rebuild for fun, how much |
Cfletch |
Dec 17 2014, 02:50 PM
Member Group: Members Posts: 104 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
Iv got my original 1.7 engine thats in need of a rebuild and I really dont need to rebuild it right now as I am working on my /6 conversion, but am curious of how much the average rebuild runs? I have never rebuilt an engine and would like to give it a try on this one.
Cap'n Krusty |
Dec 17 2014, 03:22 PM
Difficult to give you a good answer. Most likely the heads are going to be kinda worn out, and you're gonna need new everything. Plan on $2500-4000 if you do the work yourself, other than the machining that may be required. You can easily spend $2K on the heads alone. Keep in mind I have a set of NOS 1.7 high compression pistons that need to go to a good home.
The Cap'n |
JoeDees |
Dec 17 2014, 05:00 PM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
Difficult to give you a good answer. Most likely the heads are going to be kinda worn out, and you're gonna need new everything. Plan on $2500-4000 if you do the work yourself, other than the machining that may be required. You can easily spend $2K on the heads alone. Keep in mind I have a set of NOS 1.7 high compression pistons that need to go to a good home. The Cap'n Whatcha looking for on those pistons? |
Dec 17 2014, 06:09 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you maintain and reuse the Pistons and cylinders, and do a basic valve job, it will be around 2500 inclusive of the valve job.
Parts or typically about 2k. Rich |
Cap'n Krusty |
Dec 17 2014, 06:18 PM
Difficult to give you a good answer. Most likely the heads are going to be kinda worn out, and you're gonna need new everything. Plan on $2500-4000 if you do the work yourself, other than the machining that may be required. You can easily spend $2K on the heads alone. Keep in mind I have a set of NOS 1.7 high compression pistons that need to go to a good home. The Cap'n Whatcha looking for on those pistons? $450. I already have an interested party. I may also have a set of 1.8s, but I need to look. The Cap'n |
Mueller |
Dec 17 2014, 06:21 PM
If you maintain and reuse the Pistons and cylinders, and do a basic valve job, it will be around 2500 inclusive of the valve job. Parts or typically about 2k. Rich damn.....Suby is starting to look good again...the bus motor in the car I am looking at needs "work"* *have a line on a known good 1.7 but it could be gone before i am able to pull the trigger... |
Dec 17 2014, 06:24 PM
If you maintain and reuse the Pistons and cylinders, and do a basic valve job, it will be around 2500 inclusive of the valve job. Parts or typically about 2k. Rich damn.....Suby is starting to look good again...the bus motor in the car I am looking at needs "work"* *have a line on a known good 1.7 but it could be gone before i am able to pull the trigger... Yup, but I am not available for the 100 hours of research to decode these motors. Jumping in with both feet, somewhat blind is a great way to waste a lot of money for me. |
ThePaintedMan |
Dec 17 2014, 07:14 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
... which is precisely why I've put of rebuilding one for so long. At this point in my life, I need to balance the price that I pay for parts with what I actually learn in the process. Wish I had gotten into type IVs back when my dad was working on his buses in the 1980s and 1990s. Parts were so much cheaper.
At this point, the 2500 put toward rebuilding a 1.7 would be better served, for me, putting toward a baby, my house, or (eventually) a Suby conversion. More bang for the buck. For now, I wish there was someone close by who was rebuilding an aircooled motor that I could watch and learn from. Maybe I need to give Joe O'Brien a call... |
stevegm |
Dec 17 2014, 07:31 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
... which is precisely why I've put of rebuilding one for so long. At this point in my life, I need to balance the price that I pay for parts with what I actually learn in the process. Wish I had gotten into type IVs back when my dad was working on his buses in the 1980s and 1990s. Parts were so much cheaper. At this point, the 2500 put toward rebuilding a 1.7 would be better served, for me, putting toward a baby, my house, or (eventually) a Suby conversion. More bang for the buck. For now, I wish there was someone close by who was rebuilding an aircooled motor that I could watch and learn from. Maybe I need to give Joe O'Brien a call... We are getting ready to rebuild a 1.7L and going to do a full how-to article on it. Give me a month and it will be done. |
ice cold |
Dec 17 2014, 07:57 PM
Member Group: Members Posts: 90 Joined: 12-February 14 From: West Palm Beach Florida Member No.: 16,993 Region Association: South East States |
... which is precisely why I've put of rebuilding one for so long. At this point in my life, I need to balance the price that I pay for parts with what I actually learn in the process. Wish I had gotten into type IVs back when my dad was working on his buses in the 1980s and 1990s. Parts were so much cheaper. At this point, the 2500 put toward rebuilding a 1.7 would be better served, for me, putting toward a baby, my house, or (eventually) a Suby conversion. More bang for the buck. For now, I wish there was someone close by who was rebuilding an aircooled motor that I could watch and learn from. Maybe I need to give Joe O'Brien a call... Joe has my 2.0 apart now. In the process of part gathering. Give him a call it will be a little while before assembly occurs |
G e o r g e |
Dec 17 2014, 11:00 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
... which is precisely why I've put of rebuilding one for so long. At this point in my life, I need to balance the price that I pay for parts with what I actually learn in the process. Wish I had gotten into type IVs back when my dad was working on his buses in the 1980s and 1990s. Parts were so much cheaper. At this point, the 2500 put toward rebuilding a 1.7 would be better served, for me, putting toward a baby, my house, or (eventually) a Suby conversion. More bang for the buck. For now, I wish there was someone close by who was rebuilding an aircooled motor that I could watch and learn from. Maybe I need to give Joe O'Brien a call... Have you watched Jakes Type 4 engine rebuild DVD? that is is good base to start with |
Cap'n Krusty |
Dec 18 2014, 11:40 AM
Cap'n Krusty |
Dec 18 2014, 11:41 AM
stevegm |
Dec 18 2014, 02:11 PM
Cap'n Krusty |
Dec 18 2014, 05:17 PM
Sold pending payment!
stevegm |
Dec 18 2014, 05:26 PM
Lo-Fi Version | Time is now: 1st May 2024 - 03:58 PM |
