Steering wheel question…. |
Larmo63 |
Dec 18 2014, 02:01 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Where is the black tab on the plastic canceling ring (on the back of the wheel) supposed to be?
7 o'clock? 3 o'clock? 1973 914 |
SirAndy |
Dec 18 2014, 02:20 PM
Resident German Group: Admin Posts: 41,622 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Where is the black tab on the plastic canceling ring (on the back of the wheel) supposed to be? 7 o'clock? 3 o'clock? 1973 914 If i'm not mistaken, it's 9 o'clock ... (IMG:style_emoticons/default/idea.gif) |
Mike Bellis |
Dec 18 2014, 03:44 PM
Larmo63 |
Dec 18 2014, 08:34 PM
Who's on first?
Larmo63 |
Dec 19 2014, 12:15 PM
Okay….are you saying 9 o'clock looking at the wheel from the front, or the back? If I do 9:00 looking at the back of the wheel, (laying on my bench,) the wire is a real stretch to try and hook up to the butterfly. If I do 9:00 looking at it from the front, the holes don't line up the way they look like they are supposed to. There are holes that would line up, but they never were used, no marks from the lock washers.
What am I doing wrong, & by the way the horns work now. The cancel ring is wrong though. I have it at about 7:00…. Drrrr…... |
dlkawashima |
Dec 19 2014, 12:27 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
SirAndy |
Dec 19 2014, 12:29 PM
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Maybe i'm understanding your question wrong. Also, it's been a while since i had to deal with a /4 column which is why i added the "If i'm not mistaken" to my post. The turn signal lever actuates a small pin that pops out towards the center of the steering column. The tab on the steering wheel ring is supposed to be right at the pin location when the wheels are straight. That way, when the steering wheel is turned away, the pin will pop out and when the wheel is turned back, it will push the pin back, canceling the blinkers. (IMG:style_emoticons/default/popcorn[1].gif) PS: It appears that the /4 and /6 columns are different in that regard. On a /4, the tab should be at 3 o'clock when looking at the wheel mounted (NOT from the backside). On a /6, the tab should be at 9 o'clock when looking at the wheel mounted (NOT from the backside). |
Larmo63 |
Dec 19 2014, 12:43 PM
Okay, that's what I thought. That makes more sense. The problem is that it makes the horn wire uber-hard to hook up in that attitude. Maybe I'll make a longer wire.
Thank you!! |
Bob L. |
Dec 19 2014, 02:06 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 5th May 2024 - 01:13 PM |
