Cant loosen valve, on rebuilt engine |
ericoneal |
Dec 18 2014, 07:57 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
We, walterolin and I, were trying to adjust the valve on my newly rebuilt engine tonight and we couldnt get the intake valve on #1 to loosen. We found TDC, 0 mark on the fan and #1 exhaust valve adjusted just fine. The problem is that I loosened the screw completely on the intake valve and I still could not get the feeler gage in there and it wouldnt budge (slightly rattle) when we tried to shake it by hand. Its REALLY tight.
After that we turned the engine so that the valve was for sure all the way open, and nothing. The screw is all the way backed out and its completely tight no matter what position it is in. What could cause this? My engine builder told me that he adjusted all of them to .006, so it obviously was correct at some point. At a loss here.. THanks |
barefoot |
Dec 18 2014, 08:22 PM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
We, walterolin and I, were trying to adjust the valve on my newly rebuilt engine tonight and we couldnt get the intake valve on #1 to loosen. We found TDC, 0 mark on the fan and #1 exhaust valve adjusted just fine. The problem is that I loosened the screw completely on the intake valve and I still could not get the feeler gage in there and it wouldnt budge (slightly rattle) when we tried to shake it by hand. Its REALLY tight. After that we turned the engine so that the valve was for sure all the way open, and nothing. The screw is all the way backed out and its completely tight no matter what position it is in. What could cause this? My engine builder told me that he adjusted all of them to .006, so it obviously was correct at some point. At a loss here.. THanks without more info on what happened since builder did adjustment, is there any way that the pushrod could have dislodged from it's seated position in the lifter ?? |
ericoneal |
Dec 18 2014, 08:31 PM
Nothing has happened. He adjusted, gave engine to me, and I put it back in car.
We thought about the pushrod coming disloged and took the rocker off to check. |
Dec 18 2014, 08:50 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Put it at BDC and see if you can move the valve up and down.
A bit of leverage, you can move the valve....the springs are not that tough. |
messix |
Dec 18 2014, 10:03 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I would try to turn the engine over 360* while observing that valve.
sounds like you are looking at the dizzy being 180 off. |
Cap'n Krusty |
Dec 18 2014, 10:32 PM
Sounds even more like you need to use my method, which doesn't require you to do anything other than turn the engine over and watch the valves before making any adjustments. Look in the classic threads.
The Cap'n |
ericoneal |
Dec 19 2014, 07:35 AM
I know for a fact that the distributor mark is off, but we did find the 0 mark on the fan and my previous TDC mark on the flywheel.
We turned the engine so that the valve was all the way open, the screw was all the way backed out, but it was still completely tight. Will moving the engine 180 matter at this point? We are going to study up on the Krusty method and apply it this weekend, but Im not sure if that even comes into play yet.. |
pilothyer |
Dec 19 2014, 08:10 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I know for a fact that the distributor mark is off, but we did find the 0 mark on the fan and my previous TDC mark on the flywheel. We turned the engine so that the valve was all the way open, the screw was all the way backed out, but it was still completely tight. Will moving the engine 180 matter at this point? We are going to study up on the Krusty method and apply it this weekend, but Im not sure if that even comes into play yet.. Turn it so the valve is closed. |
brant |
Dec 19 2014, 08:33 AM
914 Wizard Group: Members Posts: 11,611 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Are you at tdc for #3?
ericoneal |
Dec 19 2014, 08:38 AM
ThePaintedMan |
Dec 19 2014, 10:19 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
If that doesn't work, keep in mind that people swap out fans and some folks here have reported fans where the marks were wrong or flat out missing.
If this is the case, revert to the Capn's method. You don't even need to find TDC using the fan or distributor. Simply rotate the engine till one bank is showing three valves closed (one exhaust and two intakes - rockers will be "rocking") and one valve on the opposite bank is open. This is one TDC. Then if you rotate the engine 360 degrees around, the other bank should then have three valves closed and the opposite bank has one open. This is the other TDC. |
rjames |
Dec 19 2014, 10:29 AM
I'm made of metal Group: Members Posts: 3,913 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Use Krusty's method for sure. Curious also if you have hydraulic lifters. I could imagine the following circumstances causing what you're seeing :
The valve in question being open, a hydro lifter fully pumped up to maximum lift and the pushrod not being centered on the lifter. |
stugray |
Dec 19 2014, 10:53 AM
Most of the times I hear that people cannot find TDC, it is because they are struggling just to turn the engine.
Put the rear on jackstands ( or one jackstand and one ramp). Block one wheel so it cannot turn. Pull the spark plugs Put the car in 5th gear turn the wheel and the engine will turn "almost effortlessly". Now get under the car and watch as someone else turns the engine for you. After about three complete turns without struggling, you will understand how the valves work. In fact using this method, you can find TDC#1 quite accurately without any marks. But you have to watch it go around a few times before you have that moment where it makes perfect sense. |
OU8AVW |
Dec 19 2014, 08:11 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Swivel foot adjusters?
I had to shim my rockers to allow the screws to have more adjustments out. Otherwise the swivel feet got stuck against the rocker. |
ericoneal |
Dec 22 2014, 07:59 AM
Got this one sorted out. In a fit of desperation, I took the rockers off, pulled the pushrods out and put everything back on, then it was OK. We then used the Krusty method to adjust the valves and TDC appears to be 90 degrees off.
Some help here: If the car is truly at TDC for piston 1, both valves will be closed (ie both pushrods will be all the way in and not extended)? Attached is an image down the pushrod tube BEFORE I removed everything which fixed the issue. |
SLITS |
Dec 22 2014, 08:09 AM
ThePaintedMan |
Dec 22 2014, 08:17 AM
As I said, if you're using the fan or distributor to determine TDC, keep in mind that dizzys can be reclocked a and the fan maybe have been disassembled by someone previously and put back wrong.
ericoneal |
Dec 22 2014, 08:40 AM
I saw your post, thanks, and thats one reason that we confirmed with the Krusty method. The fan, (and my previous mark on the underside of the flywheel), seems to be correct with the #1 valve positions (confirmed by SLITS above), but the dizzy is now exactly 90 degress off from its TDC mark. Knowing this, we can now proceed.
As I said, if you're using the fan or distributor to determine TDC, keep in mind that dizzys can be reclocked a and the fan maybe have been disassembled by someone previously and put back wrong. |
Bulldog9 |
Dec 22 2014, 09:06 AM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Having just finished this is fresh in my head.
Dont worry about marks, they are irrelevant until confirmed go off the #1 cyl at its top of travel (TDC) and note the position of the rotor. Imagine the distributor ROTOR is a clock hand. When at TRUE TDC, the rotor (firing end w/metal) will face at what we call 1200 (though when facing the motor from the rear of the car it will likely be more like 200 with a Bosch dizzy or if you are running a Pertronix billet like I am, will be at 1100). At TRUE TDC the #1 piston is at the top of its travel and both valves are closed, meaning there is no pressure on the lifter/pushrod/rocker assembly. Once you break loose the locking nut you should be able to back out the adjuster. The ONLY other time the #1 CYL is at the top is when the rotor is 180degrees out and it will be facing 600. The piston may be at TOP, but one of the cam l If you are truly at TDC and still cant back out the adjuster, just unbolt the whole rocker assembly for inspection. It really is easy.... If you are at true TDC, you may have a stripped/galled adjuster or your friendly mechanic used something like JB weld or super hard threadlocker when he put in the adjuster (this happened to me once) My guess is you are 180 out, and likely it is the distributor pinion. IF this is the case, you will need to take out the distributor, AND the drive pinion, and realign them. Find your TDC/#1 mark on the distributor, turn the rotor to that mark, then align the drive (only ONE way for this to go together, and re-install. Will take some giggling and possible rocking of motor). This is a job you need a second set of hand/eyes for. You said this is a NEW/rebuilt motor? Where is the mechanic on this? |
JStroud |
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I'm confused, how freshly rebuilt is this motor, I'm just wondering why you are doing all this, seems like the motor or something was setup wrong, why not take it back to the engine builder to make it right. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 23rd April 2024 - 09:50 AM |
