Cant loosen valve, on rebuilt engine |
ericoneal |
Dec 18 2014, 07:57 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
We, walterolin and I, were trying to adjust the valve on my newly rebuilt engine tonight and we couldnt get the intake valve on #1 to loosen. We found TDC, 0 mark on the fan and #1 exhaust valve adjusted just fine. The problem is that I loosened the screw completely on the intake valve and I still could not get the feeler gage in there and it wouldnt budge (slightly rattle) when we tried to shake it by hand. Its REALLY tight.
After that we turned the engine so that the valve was for sure all the way open, and nothing. The screw is all the way backed out and its completely tight no matter what position it is in. What could cause this? My engine builder told me that he adjusted all of them to .006, so it obviously was correct at some point. At a loss here.. THanks |
stugray |
Dec 23 2014, 07:54 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The most logical answer is that the mechanic set the valves, realized he forgot the retainer spring, took the rockers off to install the spring, then put the rockers back on (with one "dropped" pushrod) then chose to not recheck the valve clearance.
Lo-Fi Version | Time is now: 17th May 2024 - 11:01 PM |
