how do I remove early /6 cam sprocket? |
tornik550 |
Dec 18 2014, 08:14 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
With the 46mm crowfoot tool and cam holder tool, I removed my camshaft nut. Took a lot of force but no big deal. In Wayne's book, it seems that the cam sprocket should just slide off once the cam nut is removed. Mine will not budge. Am I missing something?
rgalla9146 |
Dec 18 2014, 08:54 PM
There is a pin in one of the sprocket holes.
Put the nut back on hand tight. Rotate the engine to TDC. Remove the chain tensioner. Take the nut and wave washer back off. Use a spark plug as a tool (remove the threaded connector) to pull the pin out. Chain is now loose. Remove sprocket. |
tornik550 |
Dec 18 2014, 09:12 PM
There is a pin in one of the sprocket holes. Put the nut back on hand tight. Rotate the engine to TDC. Remove the chain tensioner. Take the nut and wave washer back off. Use a spark plug as a tool (remove the threaded connector) to pull the pin out. Chain is now loose. Remove sprocket. I had tried all of this with one exception- I did not necessarily have the engine at TDC. Why does it need to be at TDC? I removed the nut, chain tensioner and the little pin. I thought that the sprocket should just slide off the camshaft however mine is still on their very tight. |
roblav1 |
Dec 18 2014, 09:51 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
All of mine always easily came off after removing the pin. You need to take the chain tension off the sprocket beforehand. It's not necessary to put it at TDC, but it will make life easier as you continue taking it apart.
It it's jammed on there, someone messed it up. You can't re-time the cam if that sprocket jams on it. |
rgalla9146 |
Dec 18 2014, 10:03 PM
There is no technical reason for TDC. Just a way to keep order.
But do not rotate the crank after removing the chains as long as the cams are still installed. I would lightly pry or wiggle the sprocket. It is not too thick where it goes onto the inner sprocket. |
tornik550 |
Dec 18 2014, 10:10 PM
I wasn't sure if there was a extra pin or something that I was missing. Because of everyone's instructions, ok ew that everything was off and it wouldn't hurt to pull harder. I had to start the movement by prying a slight bit then it can right off.
Lo-Fi Version | Time is now: 24th April 2024 - 11:47 AM |
