Engine Compatibility? |
VWTortuga336 |
Dec 19 2014, 07:44 AM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
I think I know the answer to this, but I want to confirm before I make a purchase - are engines interchangable between years? I know there are displacement differences, compression differences, etc. I'm wondering about fitting a later engine into an earlier car.
Specifically, will a GC code from a '75 fit in my '74? |
bandjoey |
Dec 19 2014, 09:32 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
The exhaust might not fit. I think it's 1.8 and 2.0 that r the same. 1.7 different. I know someone more knowledgable will confirm or correct.
mepstein |
Dec 19 2014, 10:08 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The exhaust might not fit. I think it's 1.8 and 2.0 that r the same. 1.7 different. I know someone more knowledgable will confirm or correct. 1.7 / 1.8 are the same. 2.0 differes. Use the heat exchangers with correct muffler and either one will work. They must be used as a pair. |
stevegm |
Dec 19 2014, 10:42 AM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
The exhaust might not fit. I think it's 1.8 and 2.0 that r the same. 1.7 different. I know someone more knowledgable will confirm or correct. 1.7 / 1.8 are the same. 2.0 differes. Use the heat exchangers with correct muffler and either one will work. They must be used as a pair. I concur. The 2.0 heat exchangers are straight, whereas the others curve up a little. Therefore, you have to use 2.0 heat exchangers with a 2.0 exhaust. I have a few sets of 2.0 heat exchangers if you need them. I don't think I have a 2.0 muffler. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:00 AM |
