Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
lsintampa |
Dec 22 2014, 02:05 PM
Well, it's about as good as I can get it.
Everything hooked up, when warm.. the idle surges between 1100 and 1200. High but if I try to get it any lower it just gets worse. It will need to do for now until I find someone that knows how to figure it out. I can do a bit - follow directions, etc., but I'm no expert for sure. As far as vacuum leaks, about the only thing I can suspect would be the plenum. I checked the FI seals (all new) - reseated them. Just about all the other seals are new - as are the hoses. Not sure if it matters, but the car WAS from CA - and had other parts that are long gone. Not sure if it had a speed limiter or not - I have the resistor pack that I think went with. The FI harness is from a 2.0 D-Jet - NON-CA car. Maybe something to do with it? I've had one issue after another - trying to get this car settled down. Little seat time, but what time I've had has been GREAT. The issue only shows up at idle - car runs great - doesn't cut out, no issues with any backfires, misses, etc. I think I'll enjoy it for a bit and drive it. Maybe when I get up enough energy to take the plenum off (again), I'll check it out. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:50 PM |
