Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
lsintampa |
Dec 22 2014, 02:05 PM
Well, it's about as good as I can get it.
Everything hooked up, when warm.. the idle surges between 1100 and 1200. High but if I try to get it any lower it just gets worse. It will need to do for now until I find someone that knows how to figure it out. I can do a bit - follow directions, etc., but I'm no expert for sure. As far as vacuum leaks, about the only thing I can suspect would be the plenum. I checked the FI seals (all new) - reseated them. Just about all the other seals are new - as are the hoses. Not sure if it matters, but the car WAS from CA - and had other parts that are long gone. Not sure if it had a speed limiter or not - I have the resistor pack that I think went with. The FI harness is from a 2.0 D-Jet - NON-CA car. Maybe something to do with it? I've had one issue after another - trying to get this car settled down. Little seat time, but what time I've had has been GREAT. The issue only shows up at idle - car runs great - doesn't cut out, no issues with any backfires, misses, etc. I think I'll enjoy it for a bit and drive it. Maybe when I get up enough energy to take the plenum off (again), I'll check it out. |
r_towle |
Dec 22 2014, 02:35 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Well, it's about as good as I can get it. Everything hooked up, when warm.. the idle surges between 1100 and 1200. High but if I try to get it any lower it just gets worse. It will need to do for now until I find someone that knows how to figure it out. I can do a bit - follow directions, etc., but I'm no expert for sure. As far as vacuum leaks, about the only thing I can suspect would be the plenum. I checked the FI seals (all new) - reseated them. Just about all the other seals are new - as are the hoses. Not sure if it matters, but the car WAS from CA - and had other parts that are long gone. Not sure if it had a speed limiter or not - I have the resistor pack that I think went with. The FI harness is from a 2.0 D-Jet - NON-CA car. Maybe something to do with it? I've had one issue after another - trying to get this car settled down. Little seat time, but what time I've had has been GREAT. The issue only shows up at idle - car runs great - doesn't cut out, no issues with any backfires, misses, etc. I think I'll enjoy it for a bit and drive it. Maybe when I get up enough energy to take the plenum off (again), I'll check it out. Best test is to go to the hardware store and buy an assortment of rubber caps. Remove every line from the plenum (after the car is warm) and cap them with the tight rubber caps. See if idle stablizes. I ran into this early on in my car, so over 10 years ago. I found that the manifold to intake runners develop a slight vacuum leak. I now put them on with RTV gasket at the head side and at the manifold side and I let it setup overnight before running the motor, leak gone. I also round leaks at the decel valve (I removed it forever) I found leaks at the AAR valve, (removed it forever) From there I found that there is only one way to set the TPS properly, and there is no possible variation. It must sit in a certain position at Idle, or its wrong. If its wrong at idle, it surges, but it also makes the car run wrong all over the place, but its hard to notice except at idle when it surges. Oh, one more thing I found was the distributor advance plates need to be cleaned and lubed because they have 40 year old grease that now behaves like glue when hot...and when the advance plates do not snap back to zero advance, the car surges at Idle. Let me see if I have the pic rich |
Lo-Fi Version | Time is now: 16th May 2024 - 01:42 AM |
