Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
r_towle |
Dec 22 2014, 02:40 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
sorry, had to get it off my phone.
See the middle brass contact finger? See how it is touching nothing? That is what it must look like at idle. The one one the left sits on the first leg. I found it alot easier to remove the throttle body along with the TPS and set it when its not in the car, so you can see everything clearly. Rich |
lsintampa |
Dec 23 2014, 10:49 AM
sorry, had to get it off my phone. See the middle brass contact finger? See how it is touching nothing? That is what it must look like at idle. The one one the left sits on the first leg. I found it alot easier to remove the throttle body along with the TPS and set it when its not in the car, so you can see everything clearly. Rich If the middle finger is "touching nothing" about the only way I could get it there was to take the TB off the car, then used a OHM meter to insure the finger was not touching the "brass tracers". The pictures I just posted - the middle finger WAS still touching. So I made just a slight adjustment - used the OHM meter to insure it was not touching and installed that into the car. To be honest, the surging is now worse than it was. Question... would the Dizzy vac be suspect? Or the Dizzy advance plates? The Dizzy is original - just new points / condenser.... The other suspect is still the Plenum. Onward through the fog.... |
Lo-Fi Version | Time is now: 15th May 2024 - 01:09 PM |
