Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
r_towle |
Dec 22 2014, 02:56 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
the reason the TPS can be adjusted is it was made for a large number of cars.
At the end of the day, it can only be positioned ONE way to work on a given throttle body. The idle circuit is a special circuit in the ECU, so it needs to have the TPS in the correct position in order to make that special circuit activate. |
lsintampa |
Dec 24 2014, 12:19 PM
the reason the TPS can be adjusted is it was made for a large number of cars. At the end of the day, it can only be positioned ONE way to work on a given throttle body. The idle circuit is a special circuit in the ECU, so it needs to have the TPS in the correct position in order to make that special circuit activate. Yeah, I think I understand what you're saying. The idle circuit is not even working if that middle finger (no pun intended) is making contact. (I think this is what you said). And if it IS touching something, you end up with a high idle - me thinks. With how my switch is set up it need to go nearly fully CCW to be "set". Seems odd to me as well, but it is at the CCW limits in order to get that middle finger off any tracers. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:37 PM |
