Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
r_towle |
Dec 26 2014, 05:51 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Tape up the holes, sink in water.
lsintampa |
Dec 27 2014, 10:48 AM
Tape up the holes, sink in water. Well that worked. What I learned - I'm not that good at taping up holes. Lucky for me, I left the cold start injector and it's mounting plate on. That's where the leak was. The outer gasket (NLA) was hand made..... poorly I might add. Bubbled up like one of those fake treasure chests in a fish tank. Anyway, I'm a bit peeved at a) myself for not finding it without going to such an extreme, and b) my motor builder that made the gasket. I never thought to second guess him. As far as going to the extreme - well at least I can rest easily that my support tubes are in good order. Should I tape them now that I have the plenum out? Seems to me the tape on the bottom side would just melt? One of the side intakes has a small ding on the lip - so it's a bit out of round. I'll crimp that out - and anyway, I'm putting clamps all around. I have some honey-do things I need to get done around the house today. So not sure if I'll get some bench time or not. I'm happy to have found a leak. (IMG:style_emoticons/default/smile.gif) Maybe I can get some good forward motion going on. (IMG:style_emoticons/default/piratenanner.gif) Not done yet, but I'm on the right path. Thanks Rich!!!! (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 12:40 PM |
