Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
lsintampa |
Dec 30 2014, 08:52 AM
At this point - it seems I may be near normal.
I reset the dwell and timing. I'm not sure why timing should be set with the car at or near 3,000 RPM? It's been my experience over the years to set timing at idle. Thinking about that, it would be next to impossible to do, when at idle, the surging was nuts. Anyway, with the help from my wife to jack the rpm's up to around 2500 - 3000, I set the timing. Ended up retarding the advance quite a bit from where it was. That seemed to drop my idle way down to under 900 RPM - and the surging seems to be near gone. I don't want to say it's resolved - it would be nice to know for sure if the timing may have been another part of the issue. (along with the leaking cold start valve). I can FORCE the surging by doing one of two things. 1) advancing the distributor a lot 2) at idle muck with the throttle plate switch - take it off it's idle setting Anyway, there have been times with I "thought" it was right - just to let it sit for a while and watch it go nuts on me. Will test again later today. Keeping fingers crossed - that maybe it's settled down? |
Lo-Fi Version | Time is now: 15th May 2024 - 12:24 PM |
