Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
lsintampa |
Jan 1 2015, 02:22 PM
Recap 75 2.0 d-jet - was a California car, cat deleted by some PO, new (used) FI harness for a non California car.
Latest update... Following Rich's guidelines.... Day 1: 1) Set idle - motor warm, RPM's at 3200, pulled vac lines off dizzy, plugged the holes to the throttle body. Timing mark did NOT move - held steady. 2) Turned ECU knob full clockwise - to full rich position. 3) Adjusted TPS - per the Pelican site. Car now idles very low - most times it will eventually stall out. Day 2: Today the motor was cold. I didn't know what to expect, but leaving everything as was, I just went for it. Car started. It took a few tries - maybe three. But it had a hard time staying running. The AAR valve was full open because I could here it sucking air. The extra air had NO effect on the idle at all. After a while the car will run, but the idle is just above stall point - and it catches itself most times, but eventually will stall out. I have a new TPS coming in. Most likely it will get here sometime next week. For what it's worth, I've never seen the ECU knob have any effect on the idle - ever. I laugh every time someone tells me to adjust it, because I know it's not going to do anything. Maybe it is broken, or the idle circuit is fried, or the TPS is shot. I think when the day comes that the knob actually has an effect on the idle, I'm gonna fall over. And yes I did try to turn ONLY the ECU knob (day 2). I'd turn the motor off, move the knob like 1/4 turn - restart. I went from full rich to full lean - no setting had any effect. I've put the knob back now to full CW (rich) position - as it was this morning. (IMG:style_emoticons/default/dead horse.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 10:20 PM |
