Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
r_towle |
Jan 3 2015, 10:29 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If that is an intake stud, it's going to make tuning the car very hard to do.
It's leaking air. |
lsintampa |
Jan 12 2015, 05:43 PM
If that is an intake stud, it's going to make tuning the car very hard to do. It's leaking air. I'm dealing with the intake stud this week - hopefully. Haven't done much else - except put a new TPS board on. But I agree it makes no sense to plod on when I know there are other issues to deal with first. Just for grins, I did pull up a picture of the motor AFTER the rebuild and in this shot if you zoom in on the intake, you can clearly see there is a BOLT in the middle where it there should be a nut on a stud. That's the oddity that I discovered when I pulled that intake off. I was expecting a nut and came out with a bolt. Putting it back on that puppy was for sure stripped and needs to be resolved. There will be an ending to this saga. Sadly for now, it lingers on. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:31 AM |
