Surge / Idle |
Surge / Idle |
Jan 27 2015, 06:08 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Suck on it, if you can make your tongue stick to the end, it's holding a vacuum.
lsintampa |
Jan 27 2015, 07:57 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
Suck on it, if you can make your tongue stick to the end, it's holding a vacuum. Well if I "suck on it", it will stick to my tongue. However, nothing inside moves, unlike the loaner MPS. So my question to you is why is there such a difference between the inside movement between the two units??? |
lsintampa |
Feb 22 2015, 10:12 AM
Well - we're done.
Issue resolved. Problems fixed: 1) rebuilt MPS - thanks to Jeff Bowlsby 2) found and fixed a stuck de-accel valve 3) cleaned up and lubed the dizzy plates 4) replaced TPS board - thanks to davesprinkle Adjusting the TPS was the most difficult to do. By chance I met someone at our last PCA social that is retired, but he worked for Bosch as a trainer on d-jet (of all things). I got some documentation on the d-jet system from him. Most of it was for VW, but parts pertained to the 914. One thing I found in that documentation was that if your surging is "wild" up and down, they suggest you adjust your tps - as r_towle said, there is only one position it can be in for idle. I tried the Pelican method - and it seems to be good. Then just for grins, I started the car an mal-adjusted the TPS - and it started surging like mad. Anyway, I'm in a good place now. (IMG:style_emoticons/default/bye1.gif) |
914_teener |
Feb 22 2015, 12:53 PM
914 Guru Group: Members Posts: 5,195 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Well - we're done. Issue resolved. Problems fixed: 1) rebuilt MPS - thanks to Jeff Bowlsby 2) found and fixed a stuck de-accel valve 3) cleaned up and lubed the dizzy plates 4) replaced TPS board - thanks to davesprinkle Adjusting the TPS was the most difficult to do. By chance I met someone at our last PCA social that is retired, but he worked for Bosch as a trainer on d-jet (of all things). I got some documentation on the d-jet system from him. Most of it was for VW, but parts pertained to the 914. One thing I found in that documentation was that if your surging is "wild" up and down, they suggest you adjust your tps - as r_towle said, there is only one position it can be in for idle. I tried the Pelican method - and it seems to be good. Then just for grins, I started the car an mal-adjusted the TPS - and it started surging like mad. Anyway, I'm in a good place now. (IMG:style_emoticons/default/bye1.gif) Nice. You motor is stock cam 2.0 with d-jet? |
lsintampa |
Feb 22 2015, 02:27 PM
Well - we're done. Issue resolved. Problems fixed: 1) rebuilt MPS - thanks to Jeff Bowlsby 2) found and fixed a stuck de-accel valve 3) cleaned up and lubed the dizzy plates 4) replaced TPS board - thanks to davesprinkle Adjusting the TPS was the most difficult to do. By chance I met someone at our last PCA social that is retired, but he worked for Bosch as a trainer on d-jet (of all things). I got some documentation on the d-jet system from him. Most of it was for VW, but parts pertained to the 914. One thing I found in that documentation was that if your surging is "wild" up and down, they suggest you adjust your tps - as r_towle said, there is only one position it can be in for idle. I tried the Pelican method - and it seems to be good. Then just for grins, I started the car an mal-adjusted the TPS - and it started surging like mad. Anyway, I'm in a good place now. (IMG:style_emoticons/default/bye1.gif) Nice. You motor is stock cam 2.0 with d-jet? correct! |
Lo-Fi Version | Time is now: 1st May 2024 - 10:46 AM |
