Intermittent Problem with Betty's car, I am at my wit's end on this one. |
ClayPerrine |
Dec 22 2014, 07:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
About 2 weeks ago, Betty came home and said her 74, 1.8L Ljet 914 was intermittently cutting out. I took it out to test drive it, and sure enough, it will randomly cut out. Sometimes mildly, sometimes it feels like the engine shuts off completely, then turns back on.
So I started troubleshooting. Nope, grounds for the injectors are fine. Put the LM-1 in the tailpipe and had her drive it. Every time it cuts out, the LM-1 shows it going lean. I put an L-Jet tester I have on it and ran through all the tests and it shows as working fine. I had it running in the garage, and I went through a "wiggle test", wiggling every wire and connection on the engine. Nothing I do can replicate the issue in the garage. So I started throwing parts at it. To date I have replaced: The air flow meter. The fuel injection wiring harness. The double relay. The dropping resistors. The fuel pump. The ECU. The CHT. The whole distributor with a different pertronix, and tried points too. Nothing I have done to date helps. So I am hoping the collective knowledge of this place will help. I have checked all the simple stuff already. This is going to be hard to fix, whatever it is. I am now to the (IMG:style_emoticons/default/WTF.gif) stage, and looking for suggestions. |
JeffBowlsby |
Dec 22 2014, 08:51 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Maybe its fuel related? dirty tank sock? dirty fuel filter? intermittent pump? clogged injectors? Failing resistor pack?
Maybe its ignition related, coil going bad? plug wires broken? Cap/rotor ok? |
SirAndy |
Dec 22 2014, 09:40 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Maybe its fuel related? dirty tank sock? dirty fuel filter? (IMG:style_emoticons/default/agree.gif) My money is on the fuel filter or the tank sock ... (IMG:style_emoticons/default/popcorn[1].gif) |
ClayPerrine |
Dec 22 2014, 10:08 PM
Maybe its fuel related? dirty tank sock? dirty fuel filter? (IMG:style_emoticons/default/agree.gif) My money is on the fuel filter or the tank sock ... (IMG:style_emoticons/default/popcorn[1].gif) I don't have a tank sock any more. I have a carburetor fuel filter in line in front of the pump. And both were replaced yesterday. We just drove it to the grocery store. Still having the problem, but I spent most of the trip wiggling the key. Still can't make it happen on demand. (IMG:style_emoticons/default/headbang.gif) One time it happened at light throttle. Maybe one injector going and it feels worse than it really is??? |
Lo-Fi Version | Time is now: 18th May 2024 - 12:51 PM |
