Intermittent Problem with Betty's car, I am at my wit's end on this one. |
ClayPerrine |
Dec 22 2014, 07:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,482 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
About 2 weeks ago, Betty came home and said her 74, 1.8L Ljet 914 was intermittently cutting out. I took it out to test drive it, and sure enough, it will randomly cut out. Sometimes mildly, sometimes it feels like the engine shuts off completely, then turns back on.
So I started troubleshooting. Nope, grounds for the injectors are fine. Put the LM-1 in the tailpipe and had her drive it. Every time it cuts out, the LM-1 shows it going lean. I put an L-Jet tester I have on it and ran through all the tests and it shows as working fine. I had it running in the garage, and I went through a "wiggle test", wiggling every wire and connection on the engine. Nothing I do can replicate the issue in the garage. So I started throwing parts at it. To date I have replaced: The air flow meter. The fuel injection wiring harness. The double relay. The dropping resistors. The fuel pump. The ECU. The CHT. The whole distributor with a different pertronix, and tried points too. Nothing I have done to date helps. So I am hoping the collective knowledge of this place will help. I have checked all the simple stuff already. This is going to be hard to fix, whatever it is. I am now to the (IMG:style_emoticons/default/WTF.gif) stage, and looking for suggestions. |
dakotaewing |
Dec 22 2014, 10:23 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Is this all on the same tank of gas? What grade fuel is in the tank? Consider as gas gets cheaper, the big guys at the refinery are going to consider ways to maintain profits. What additives are in the fuel this week? I started running Super in my cars 3 weeks ago, and noticed a remarkable difference in temperament just running around town. Consider getting a fuel additive for the current tank of gas, in order to increase the octane.
ClayPerrine |
Dec 22 2014, 10:27 PM
Is this all on the same tank of gas? What grade fuel is in the tank? Consider as gas gets cheaper, the big guys at the refinery are going to consider ways to maintain profits. What additives are in the fuel this week? I started running Super in my cars 3 weeks ago, and noticed a remarkable difference in temperament just running around town. Consider getting a fuel additive for the current tank of gas, in order to increase the octane. It happened at the tail end of a tank of gas. I filled the tank and added stuff to dry out any water thinking it might be condensation or some ethanol absorbing water. And we always run premium in her car. 2.0 flat top pistons with 1.8L heads makes it a requirement to keep from pinging. |
Lo-Fi Version | Time is now: 25th May 2024 - 04:39 PM |
