Intermittent Problem with Betty's car, I am at my wit's end on this one. |
ClayPerrine |
Dec 22 2014, 07:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
About 2 weeks ago, Betty came home and said her 74, 1.8L Ljet 914 was intermittently cutting out. I took it out to test drive it, and sure enough, it will randomly cut out. Sometimes mildly, sometimes it feels like the engine shuts off completely, then turns back on.
So I started troubleshooting. Nope, grounds for the injectors are fine. Put the LM-1 in the tailpipe and had her drive it. Every time it cuts out, the LM-1 shows it going lean. I put an L-Jet tester I have on it and ran through all the tests and it shows as working fine. I had it running in the garage, and I went through a "wiggle test", wiggling every wire and connection on the engine. Nothing I do can replicate the issue in the garage. So I started throwing parts at it. To date I have replaced: The air flow meter. The fuel injection wiring harness. The double relay. The dropping resistors. The fuel pump. The ECU. The CHT. The whole distributor with a different pertronix, and tried points too. Nothing I have done to date helps. So I am hoping the collective knowledge of this place will help. I have checked all the simple stuff already. This is going to be hard to fix, whatever it is. I am now to the (IMG:style_emoticons/default/WTF.gif) stage, and looking for suggestions. |
fignewton |
Dec 23 2014, 12:55 PM
Newbie Group: Members Posts: 18 Joined: 4-September 13 From: N. VA Member No.: 16,346 Region Association: MidAtlantic Region |
probably not your problem, but one time with a 240Z, I dumped a bottle of carb cleaner in the tank just to realize as i tilted it that the cardboard stuff under the cap was still stuck to the long neck...just as it disappeared down the filler neck. Every time I'd get below a quarter tank, it would intermittently get sucked over the fuel pickup in the tank and the car would not get fuel. Sometimes it would just run badly; others it would run completely out (3 Webers). Had to pull the tank to finally solve the problem.
Lo-Fi Version | Time is now: 18th May 2024 - 04:51 PM |
