Intermittent Problem with Betty's car, I am at my wit's end on this one. |
ClayPerrine |
Dec 22 2014, 07:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,482 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
About 2 weeks ago, Betty came home and said her 74, 1.8L Ljet 914 was intermittently cutting out. I took it out to test drive it, and sure enough, it will randomly cut out. Sometimes mildly, sometimes it feels like the engine shuts off completely, then turns back on.
So I started troubleshooting. Nope, grounds for the injectors are fine. Put the LM-1 in the tailpipe and had her drive it. Every time it cuts out, the LM-1 shows it going lean. I put an L-Jet tester I have on it and ran through all the tests and it shows as working fine. I had it running in the garage, and I went through a "wiggle test", wiggling every wire and connection on the engine. Nothing I do can replicate the issue in the garage. So I started throwing parts at it. To date I have replaced: The air flow meter. The fuel injection wiring harness. The double relay. The dropping resistors. The fuel pump. The ECU. The CHT. The whole distributor with a different pertronix, and tried points too. Nothing I have done to date helps. So I am hoping the collective knowledge of this place will help. I have checked all the simple stuff already. This is going to be hard to fix, whatever it is. I am now to the (IMG:style_emoticons/default/WTF.gif) stage, and looking for suggestions. |
malcolm2 |
Dec 29 2014, 10:38 PM
Will we be seeing a FS post from you soon? You have lots of spare parts now, that's for sure.
Hope you found it. As I remember, it is a good feeling. |
ClayPerrine |
Dec 30 2014, 07:18 AM
Will we be seeing a FS post from you soon? You have lots of spare parts now, that's for sure. After almost 30 years of owning and working on 914s, I have LOTS of spare parts. I buy up the L-Jet fuel injection parts as soon as I can, because they are getting rarer. I also have lots of heater parts, engine tin, and windage trays too. I even have bus alternator harnesses that were mis-labeled as for a 914. They have a pigtail off the 3 pin connector to hook up the charge light circuit. They would be perfect for someone with carbs who wants to eliminate the relay board. |
Lo-Fi Version | Time is now: 25th May 2024 - 04:38 PM |
