Intermittent Problem with Betty's car, I am at my wit's end on this one. |
ClayPerrine |
Dec 28 2014, 08:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,438 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Since the problem is related to the charging system I would swap in another regulator before pulling the alternator. Why did you change the alternator to begin with? I changed the alternator because it stopped charging. Before I changed it, I did a full field test on the old one. It would not charge even then. Fro those that don't know, you can jump battery positive power to the field wire on the alternator. That will cause the alternator to charge max output. Don't do it for long, because you will burn up the battery. But it is a good test to see if you have a bad regulator or a bad alternator. Thanks to everyone who offered suggestions on this. I appreciate the help. (IMG:style_emoticons/default/smilie_pokal.gif) |
ThePaintedMan |
Dec 28 2014, 10:37 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
That's why I suggested looking into the charging system early on in the thread... Glad you found it...hopefully
Dec 28 2014, 11:09 PM
What a saga, hope this is the cure.
timothy_nd28 |
Dec 28 2014, 11:39 PM
I'm late to the party here, glad it's working at the moment. I'm having trouble on how the alternator would cause the Ljet to quit working, seems unrelated (IMG:style_emoticons/default/confused24.gif)
Cap'n Krusty |
Dec 29 2014, 12:05 AM
Both D-jet and L-jet require a minimum voltage, and the voltage needs to be pretty constant.
The Cap'n |
Cap'n Krusty |
Dec 29 2014, 12:06 AM
Oh, it's around 11v, maybe 11.5, IIRC. Been a while since I looked it up.
The Cap'n |
timothy_nd28 |
Dec 29 2014, 12:16 AM
100% agree with you on the low voltage situation, but he re-started the car every time the engine cut out. If the battery was going flat, enough to drop out the Ljet, then he would of needed a jump every time, which is a detail that I didn't read in the earlier posts.
Dec 29 2014, 12:39 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Oh, it's around 11v, maybe 11.5, IIRC. I know from personal experience that the D-jet will work pretty decently until the center console voltmeter drops below 9V. I don't know what the actual system voltage was, but when things got low enough the engine would die every time I hit the brakes. It also cut out in time with the lights when I used my turn signal. I almost made it home that time... Got about a half-dozen blocks away and then a light turned red just before I got to it. --DD |
ClayPerrine |
Dec 29 2014, 06:15 AM
Bartlett 914 |
Dec 29 2014, 09:01 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Is the belt tight? Is the alternator well grounded?
Dec 29 2014, 03:26 PM
ClayPerrine |
Dec 29 2014, 03:30 PM
I suspect it is a blown diode causing a reverse voltage spike. You've got an O-scope, don't you? Time to check the voltage with it! --DD I also have a freshly rebuilt alternator that was already scheduled to be installed on her car tonight. (IMG:style_emoticons/default/biggrin.gif) |
Dec 29 2014, 03:35 PM
I suspect it is a blown diode causing a reverse voltage spike. You've got an O-scope, don't you? Time to check the voltage with it! --DD I also have a freshly rebuilt alternator that was already scheduled to be installed on her car tonight. (IMG:style_emoticons/default/biggrin.gif) the one real man repair on these cars is the alternator in place... rich |
57lincolnman |
Dec 29 2014, 08:37 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
About 2 weeks ago, Betty came home and said her 74, 1.8L Ljet 914 was intermittently cutting out. I took it out to test drive it, and sure enough, it will randomly cut out. Sometimes mildly, sometimes it feels like the engine shuts off completely, then turns back on. So I started troubleshooting. Nope, grounds for the injectors are fine. Put the LM-1 in the tailpipe and had her drive it. Every time it cuts out, the LM-1 shows it going lean. I put an L-Jet tester I have on it and ran through all the tests and it shows as working fine. I had it running in the garage, and I went through a "wiggle test", wiggling every wire and connection on the engine. Nothing I do can replicate the issue in the garage. So I started throwing parts at it. To date I have replaced: The air flow meter. The fuel injection wiring harness. The double relay. The dropping resistors. The fuel pump. The ECU. The CHT. The whole distributor with a different pertronix, and tried points too. Nothing I have done to date helps. So I am hoping the collective knowledge of this place will help. I have checked all the simple stuff already. This is going to be hard to fix, whatever it is. I am now to the (IMG:style_emoticons/default/WTF.gif) stage, and looking for suggestions. |
57lincolnman |
Dec 29 2014, 08:40 PM
Sort of late to this discussion but I had a cut out problem similar to what you describe. It was the temperature head sensor. It was not seated properly causing it to cut out. I tried similar things but once I replaced that, the car ran fine. If you still have problems, you might want to look at that.
malcolm2 |
Dec 29 2014, 10:38 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Will we be seeing a FS post from you soon? You have lots of spare parts now, that's for sure.
Hope you found it. As I remember, it is a good feeling. |
Dec 29 2014, 10:44 PM
I also have a freshly rebuilt alternator that was already scheduled to be installed on her car tonight. (IMG:style_emoticons/default/biggrin.gif) I'd still suggest checking the voltage with an O-scope. It will give you more confidence that the alternator was the problem--and will tell you what kind of problem it was. --DD |
rick 918-S |
Dec 29 2014, 10:48 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Relay board failing.
ClayPerrine |
Dec 30 2014, 07:18 AM
Will we be seeing a FS post from you soon? You have lots of spare parts now, that's for sure. After almost 30 years of owning and working on 914s, I have LOTS of spare parts. I buy up the L-Jet fuel injection parts as soon as I can, because they are getting rarer. I also have lots of heater parts, engine tin, and windage trays too. I even have bus alternator harnesses that were mis-labeled as for a 914. They have a pigtail off the 3 pin connector to hook up the charge light circuit. They would be perfect for someone with carbs who wants to eliminate the relay board. |
rgalla9146 |
Dec 30 2014, 08:24 AM
A little late and a bit off topic but.....
Disconnect the alternator and run the car ? Doesn't that damage the alternator ? |
Lo-Fi Version | Time is now: 5th May 2024 - 10:07 PM |
