Intermittent Problem with Betty's car, I am at my wit's end on this one. |
Spoke |
Dec 30 2014, 08:39 AM
A little late and a bit off topic but..... Disconnect the alternator and run the car ? Doesn't that damage the alternator ? Yes it is a possibility if the engine is running. It is called a Load Dump and is normally associated with disconnecting the battery since batteries receive most of the maintenance and battery cables/terminals can become corroded/oxidized. In this case, I think he only disabled the alternator by removing the control voltage to the armature. No issues here. I agree with Dave to look at the battery/alternator voltage with an oscilloscope. Voltmeters are great but can't show any voltages that are moving or spiking quickly. |
ClayPerrine |
Dec 30 2014, 03:22 PM
Life's been good to me so far..... Group: Admin Posts: 15,438 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Spoke |
Dec 30 2014, 08:03 PM
Lo-Fi Version | Time is now: 5th May 2024 - 10:32 PM |
