tunacan.net?, Engine Displacement Chart |
VaccaRabite |
Dec 23 2014, 04:41 PM
En Garde! Group: Admin Posts: 13,407 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
What happened to Tunacan.net?
Zach |
Mark Henry |
Dec 23 2014, 04:53 PM
A quick google search found it, looks like Tuna changed the address, likely he forgot to renew the domain and it got scooped. Instead of paying the extortion to get it back he just registered a new name. That or he piggybacked it on the old ladies domain to save coin.
http://www.moonrosedesigns.com/tunacannet/t4/index.shtml |
rick 918-S |
Dec 23 2014, 05:04 PM
Hey nice rack! -Celette Group: Members Posts: 20,353 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Who is tuna? Is this Jakes old site?
Mark Henry |
Dec 23 2014, 05:46 PM
Who is tuna? Is this Jakes old site? (IMG:style_emoticons/default/rolleyes.gif) The world doesn't revolve around Jake... |
VaccaRabite |
Dec 23 2014, 06:33 PM
Huh. Half his links look like they are down. He had a handy chart of crank size and piston diameter and what displacement they made. Anyone have a copy of it?
Zach |
Dec 23 2014, 07:06 PM
Custom Member Group: Members Posts: 24,499 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Zach, search google, there are three or four places that tried to coy his site, only one of them works right...can't recall which one.
Might have been inside shop talk forums.... |
Dec 23 2014, 11:30 PM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The Internet Wayback Machine has archived copies:
https://web.archive.org/web/*/http://tunacan.net/t4 The most recent one seems to be from April 2014. --DD |
VaccaRabite |
Dec 25 2014, 08:47 PM
For the next time I am looking for it. |
Jake Raby |
Dec 25 2014, 10:35 PM
Dec 26 2014, 09:53 AM
Are there any cooling fins on the 112 mm cylinders?
Oh, please post a pic of those next to some stock stuff......it would be cool to see. |
rick 918-S |
Dec 26 2014, 10:27 AM
That one isn't MassIVe enough. Here's mine Blue are stock displacements, orange are my favorite classic combos and bold red are my current displacements. That's Cool! Thanks Jake! I agree with Rich. It would be interesting to see a side by side. (IMG:style_emoticons/default/yikes.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Woody |
Dec 27 2014, 01:41 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
saigon71 |
Dec 28 2014, 07:46 AM
Senior Member Group: Members Posts: 1,990 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Cool tables!
What is the largest crank that can be used that doesn't require additional work in the case for clearance? Is it anything over 71MM? |
Jake Raby |
Dec 28 2014, 11:47 AM
That one isn't MassIVe enough. Here's mine Blue are stock displacements, orange are my favorite classic combos and bold red are my current displacements. Holy crap! 112x80? What kind of dyno numbers are you seeing? Is this an engine that is supposed to last longer than 20,000 miles? With the proper machining and practices bigger doesn't mean shorter life. To fit a bore larger than 107mm you must alter the bore centerlines of the case. This is not easy to do. The 112mm cylinders are thicker than a 103mm and have the deepest cooling fins radially, with just as many fins per inch as any other LN cylinder. Anything is possible, it just gets much, much harder to create an efficient engine when it gets bigger and bigger. The only way to feed an engine like this is with Porkies heads, some twisted wedge action and splayed valves. |
Woody |
Dec 29 2014, 07:25 AM
That one isn't MassIVe enough. Here's mine Blue are stock displacements, orange are my favorite classic combos and bold red are my current displacements. Holy crap! 112x80? What kind of dyno numbers are you seeing? Is this an engine that is supposed to last longer than 20,000 miles? With the proper machining and practices bigger doesn't mean shorter life. To fit a bore larger than 107mm you must alter the bore centerlines of the case. This is not easy to do. The 112mm cylinders are thicker than a 103mm and have the deepest cooling fins radially, with just as many fins per inch as any other LN cylinder. Anything is possible, it just gets much, much harder to create an efficient engine when it gets bigger and bigger. The only way to feed an engine like this is with Porkies heads, some twisted wedge action and splayed valves. I was going to ask what the heads look like. Very cool. |
Slider |
Feb 23 2015, 12:41 AM
Problems are like cockroaches you find 1 and theres a 100 more Group: Members Posts: 223 Joined: 11-March 07 From: Fort Collins Colorado Member No.: 7,591 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 28th March 2024 - 01:26 PM |
