Clutch cable adjust-tried everything-pedal has to be pushed all way to floor |
jjs3rd914 |
Dec 28 2014, 11:37 AM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
72 914-4 with 73 side shift tranny and shift linkage. Only 5000 miles on new PP, TO bearing, and clutch disc. Cannot remember is had flywheel surfaced as was 5 years ago. All new plastic cup bushings etc installed on clutch fork.
Since installation have had to push pedal all way to floor to get into gear. Have read all the past many threads on clutch cable adjustment. Have set the "1/2" inch free pedal play by adjusting the two 11mm nuts on cable at tranny and have to keep pedal absolutely nailed to the floor to shift with out grinding. Even went from 1/2 inch of free play to zero by adjusting the 11mm nuts tighter and it has made little difference. Anyone have any ideas? I am leaning towards the ball pivot not having enough of a washer spacing. Cannot remember what we installed. Dumb as knowing this could answer the issue. Clutch tube is solid, pedal cluster rebuilt, new clutch cable. Any ideas other than pulling tranny. Some past threads say to forget the free play and to adjust the cable tightness until get clutch engagement 1/4 to 1/3 the way up on the pedal from full down. I am reluctant to do that as I indicated we already adjusted for zero free pedal play and by going even tighter would start to have clutch slipping? Thanks jjs3rd914 |
Larry.Hubby |
Dec 28 2014, 07:40 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
You say the clutch tube is solid, but are you sure? If the rear end of the guide tube is solidly welded at the firewall but the front end of the tube has broken loose, the first inch or two of clutch pedal travel will just flex the tube to straighten it out before there's any movement of the release lever. When my clutch tube broke loose many moons ago the clutch behaved much the way you're describing. I could just barely disengage the clutch no matter how I adjusted the cable.
BeatNavy |
Dec 28 2014, 08:10 PM
You say the clutch tube is solid, but are you sure? If the rear end of the guide tube is solidly welded at the firewall but the front end of the tube has broken loose, the first inch or two of clutch pedal travel will just flex the tube to straighten it out before there's any movement of the release lever. When my clutch tube broke loose many moons ago the clutch behaved much the way you're describing. I could just barely disengage the clutch no matter how I adjusted the cable. (IMG:style_emoticons/default/agree.gif) If you're sure the clutch tube is not moving, then that's not it. But if you have even the slightest doubt, check for movement again. Because the symptoms do sound similar to what I experienced with a broken clutch tube. Twice. |
Lo-Fi Version | Time is now: 27th May 2024 - 09:01 PM |
