Ignition Wiring Harness Stock 6 |
xsurfer |
Dec 31 2014, 03:52 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I forgot how the harness connects.
From the relay panel the harness has a eyelet to the coil. Is that to the positive or negative? The opposite side of the coil has an eyelet to ground connection is that correct? There is an eye connection next to the chain cover on the right side of the engine is this correct? It harness then connects to the cdi unit. Thanks. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 08:49 AM |
