A/C on a 3.2 Conversion, Building an A/C system |
McMark |
Jan 5 2015, 09:13 PM
We're doing an A/C install on a 3.2 project car and I though ya'll might like to see how it goes.
First I made a rough mockup of the location to test fit the setup in the car. This is just a TINY bit too high. I need to move it down and outwards a bit to clear things. Once I had the general location I started making paper templates of the mount. It's a bit like putting together a puzzle, but instead of finding where pieces go, you just make your own as you go along. This will be made out of 1/8" plate most likely. The three circles you see will be bolts. The mount will be two pieces -- one underneath the tin and one on top. The tin will be sandwiched in between the two. Oh man. How do I STILL not have a CNC plasma cutter. (IMG:style_emoticons/default/headbang.gif) |
JmuRiz |
Jan 5 2015, 09:18 PM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Very neat, a higher power engine like a 3.2 or 3.6 would have no issues with a/c.
Didn't someone modify 3.2 heat exchangers on their /6 conversion? Good heat and a/c would be a dream on a 914/6! |
McMark |
Jan 5 2015, 09:19 PM
These are just typical 914-6 headers. This car may also be getting a gas heater system. (IMG:style_emoticons/default/happy11.gif)
shoguneagle |
Jan 5 2015, 09:56 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
The 3.2 heat exchangers can be modified and used. The modification relates to having a straight shift bar from the firewall to the shift point on the transmission and putting a trough for clearance in the left heat exchanger.
I have modified my left exchanger to reflect these changes and they are working including the shifting. Not a big issue other than taking your time to set the clearances and making sure the shift rod works properly. |
Mark Henry |
Jan 5 2015, 09:58 PM
What would be real cool, or should I say hot, is if you could reverse the AC and turn it into a heatpump. (IMG:style_emoticons/default/smile.gif)
ConeDodger |
Jan 5 2015, 10:28 PM
Apex killer! Group: Members Posts: 23,595 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
No no no! I do not want to see how it goes!
GeorgeRud |
Jan 5 2015, 11:05 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Does anyone have a picture of the factory 911 heat exchangers used on a 914? I'm trying to imagine the routing of the exhaust and warm air, but can't quite wrap my head around this.
JStroud |
Jan 5 2015, 11:08 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
No no no! I do not want to see how it goes! (IMG:style_emoticons/default/agree.gif) I'm with Rob.....if it goes well it could eventually cost me a lot of $$ (IMG:style_emoticons/default/happy11.gif) |
JStroud |
Jan 5 2015, 11:11 PM
Mark, with that hanging over to the side so far would this have to be installed after the engine was in the car? Seems like maybe the bracket too. Fun project.
jeeperjohn56 |
Jan 5 2015, 11:30 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Mark, when you get this figured out give me a call and let me know what the cost will be. what kind of condenser are you using?would the stock one up front work? let me know when you get it worked out. John
McMark |
Jan 6 2015, 02:08 PM
Mark, with that hanging over to the side so far would this have to be installed after the engine was in the car? Seems like maybe the bracket too. Fun project. No, this will clear the engine shelf. I'm using the 914-6 tins as my guide. The compressor itself may have to be mounted after the engine is in, but that can be a good thing. If you have to pull the motor, it's nice to leave the AC lines unopened. Mark, when you get this figured out give me a call and let me know what the cost will be. what kind of condenser are you using?would the stock one up front work? let me know when you get it worked out. John The condenser is an aftermarket unit. There really isn't anything fancy about a condenser. So we find one that works with whatever space restrictions we have. Also, making it as large as possible increases efficiency. |
GeorgeRud |
Jan 6 2015, 03:11 PM
I wonder if there is enough clearance to allow a condenser to be fitted under the engine lid (aka 911). If one would modify the lid to a 914-6GT double grill, it could allow a large condenser and allow a shorter hose run than a front trunk mounted one.
Please keep us informed. |
Cairo94507 |
Jan 6 2015, 04:52 PM
Michael Group: Members Posts: 9,778 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Just what I do not want to see.....the one aspect of my build on my car is that it does not have AC and here in the San Ramon Valley, it can get hot in the summer and early fall.
I am amazed with all of the hot roders out there installing custom AC units that fit into ashtrays, or so it appears, that we don't have a very compact and reliable unit to fit the 911 motored 914's - including the stock 3.2. I would love for my Six to have AC but that may bring the 914 Gods down on me..... |
Dave_Darling |
Jan 6 2015, 05:17 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Mark, I recall some concern about the mounting locations for other similar setups on 911 engines in the past. Specifically that the chain housing studs may not have been up to the stress and vibration of the compressor in the long run. Do you think that the extension of the mount that goes all the way to the motor mount will take enough of the load for that to not be an issue?
--DD |
Mueller |
Jan 6 2015, 05:27 PM
Nice mock-up Mark...if you need some billet parts CNC'd, let me know...I'll gladly do them for credit on that other motor!
76-914 |
Jan 6 2015, 05:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If that's a rotary compressor it won't vibrate nearly as much as the older units. Hey Mark, I'm watching this thread in hopes of receiving some enlightenment. I'd really like to learn the order in which the various components are installed, hose sizes, parts compatibilities, charging the system blah, blah. I hope to add AC within 18 months to Kugel which already has a compressor. (IMG:style_emoticons/default/popcorn[1].gif)
crawler |
Jan 6 2015, 05:59 PM
Newbie Group: Members Posts: 20 Joined: 25-July 08 From: mesa, Arizona Member No.: 9,356 Region Association: None |
If you guys ever get to Phoenix Arizona and need machine work. (Aerospace machine shop) give us a call. 480-926-2127
Mueller |
Jan 6 2015, 06:18 PM
If you guys ever get to Phoenix Arizona and need machine work. (Aerospace machine shop) give us a call. 480-926-2127 You don't use FedEX or the US Postal service (IMG:style_emoticons/default/smile.gif) Nice little Mori lathe you've got! |
McMark |
Jan 6 2015, 09:30 PM
Mark, I recall some concern about the mounting locations for other similar setups on 911 engines in the past. Specifically that the chain housing studs may not have been up to the stress and vibration of the compressor in the long run. Do you think that the extension of the mount that goes all the way to the motor mount will take enough of the load for that to not be an issue? --DD Yeah, I learned from those setups. This attaches to the motor mount, and that's it. The first three pictures in the thread are just a mockup mount. I needed to confirm the location would work without hitting the body. The real one (paper mockup) doesn't touch the chain housings, cam towers, etc. I won't know if it's rigid enough until I make it, but that's the next phase. |
TravisNeff |
Jan 7 2015, 09:12 AM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:37 AM |
